Tim's Performance Blue S1600 *2.0 ECOBOOST ENGINE SWAP, 370lbft 270whp*
#41
S1600 Owner
Got an St170 rear setup coming so that I can measure up for some brackets then ill get them fitted. Then going to get the mountune front setup (320mm discs with Alcons four pots) should be adequate for now :P
#42
S1600 Owner
S1600 Owner
Different Bolt pattern, sizes, etc etc.
They went with a stub axle inside the brake drum with this fiesta as opposed to the mk6 so the drum fits onto the wheel studs like a disc does on the front. Also locates with two high tensile studs that are fitted to the rear beam.
Ideally if the bracket works fine going to sell it to the other mk7 owners and make their lives easier when they want to swap to rear discs.
*nice alcons on the focus btw only just saw the photo*
#46
S1600 Owner
really? with the st170 hubs? tell me more.
did you remove the studs that are there?
honestly though they were different.... did it effect track width?
#47
They bolted straight on mate same flange on all fords tbh the track was as good as the same tbh if you want to widen it tho you can use racing puma or sport Ka beam spacers hardest bit about the job was undoing the bolts lol
#50
S1600 Owner
Just checked the St170 hubs again....no joy, different bolt pattern......need to investigate more me thinks.
Car is going to will pedley in June for the engine and then I'll have it back in July when I'm back from Mexico :P
#53
S1600 Owner
Different bolt pattern from hub to rear beam.... still can't find availability or prices for the new fiesta st hub so just gonna make brackets for now.....impatience at its best :P
#54
S1600 Owner
right so no discount on ap's as they have already developed the kit just finding it hard to sell because it doesnt fit behind standard wheels.
no quote as of yet for the brackets as no one wants to set up for a one off so going to leave that to will whilst he has the car.
in better news car is due to go over to leeds a week tomorrow =D cannot wait!!!! woop!!
so hopefully you will get to see some progress pics.
also mountune said they are releasing the fiesta alcons in red within a few weeks they are just waiting on stock.
/tim
/tim
#55
S1600 Owner
freshly arrived, new discs and pads and handbrake cable. In addition ordered braided lines for the new fiesta st from hel (front and rear) so if the budget doesnt yet stretch to alcons i can fit braided all around for a few months with the rear discs...still waiting for delivery of them though.
IMG_00000185_zps44511a00.jpg?t=1370348884
and a picture from when the car was clean last week....getting its bead on :P
IMG_00000179_zps44c807f0.jpg?t=1370435217
/tim
/tim
#58
S1600 Owner
IMG_00000187_zps789c33ac.jpg?t=1370451240
boom fiesta st mk7 braided lines..... rear disc conversion is a go as soon as the brackets are made =]
just got black to match the goodridge hoses on the mountune front brakes when i get them or if the hel banjo is the same size ill keep hel all round.
/tim
/tim
#61
S1600 Owner
Cheers Will, ive done my best with cleaning the rust off the calipers and carriers but ive lost my wire brush set and haven't got time now...damn.
will be over sometime sunday afternoon =]
#62
#63
S1600 Owner
Just been over to see Mr Will Pedley so the car is in his very capable hands.....feasibility report to come tomorrow which we are confident in and then onwards and upwards.
Exciting times!
/tim
Exciting times!
/tim
#69
willpedleyracing.co.uk
Management system is still in development by one of my technical partners
Goal is to maintain full functionality of the OEM dash, stalks etc. via a modified CAN system as well as keeping everything that makes the Ecoboost engine what it is: Drive by wire, twin variable cam timing and direct injection!
In other news - the old engine is nearly out
#70
#73
Looking good nice and quick work from will think I need you to put my frs back together will I've not got the motivation lol can't wait to see an update what power is it gunna make? I fancy frs ing my zs
#76
Wing stand is something that goes over the top of the engine bay, rests on the flat section on the top part of the wing (under where the bonnet rests) and allows you to suspend the engine from it. Very useful when doing clutches as it allows you to undo the gearbox mount and still control the engine position.
Would have been really useful on the mock fitment of the Ecoboost but this shape fiesta doesn't have the surface area on the top of the wings to use one.
So i've had to use the engine crane and an assortment of chains and brackets:
So - it does indeed fit width wise.
Got to take the scuttle panel and bonnet off now to allow me to get a bit further in with the crane to establish driveshaft position for the box etc.
#80
Well, came in for a few hours today and made some progress...
First job was to take the bonnet and the scuttle panel off, it wasn't making things any easier positioning the new engine with the crane!
Then, with the extra access and a bit of fettling of various mounts etc. this didn't take too long!
Which allowed suitable clearance either side:
And then, another moment of truth - would the fan assembly go back on?
It does sit some 10cm taller than the old engine, but until i've made new engine / gearbox mounts I won't be able to refit the bonnet to check for clearance. So far though, the highest point is around the same level as the brake fluid reservoir so i'm not unduly concerned yet!
Hopefully tomorrow I can get some drawings done for the new mounts and get them away to my machinist!
