One more 2wd
Old May 28, 2012 | 12:37 PM
NoNoCos's Avatar
NoNoCos
Default One more 2wd
Hi guys !
Here is a pregnant garage with a nice baby almost ready to go out
Before to have this one, I had another baby which I loved a lot
But on an icy winter, sideways have been to closed of the car...
So, I took off everything from the car : engine, gearbox, all interior parts and think about the future...
I'm sorry, but it has been impossible to take off the wheel in the trunk
So, few months after I bought a new 2wd, it was a car which wasn't running a lot, but I used it every weekend, changed all sensors and hoses, it was starting to run pretty well, but on a beautiful autumn day, the head gasket decided to blown on a straight line at 120mph...
Then, it was a good time to rebuild the old engine from my first 2wd, and put it in this one.
So I took the dead one out
and started to rebuild with the following specs :
Bloc 205
Bottom end balanced
Big wing sump + sump baffle
All ARP studs (crankshaft, con rods, head)
Cosworth pistons 7.2
High Pressure oil pump
Cometic head gasket
Head polished and enlarged
New valves and guides
BD10 and BD14 + double springs +vernier pulleys
Plenum AutoSpecialists
Injectors Siemens 83lb
Turbo T4 RS500
ProAlloy RS500 intercooler
ProAlloy water radiator
ProAlloy turbo after cooler
Bloc skimmed and piston-bore gap of 0.1mm lol it will smoke
I also did the plastigage for crankshaft and conrods, and I've been very happy about it as I have 0.05mm for every one
The only thing now is that I have the piston going out of 1.04mm from the bloc because I skimmed it three times in the way to have a good surface aspect...Damn I will have to put a thick head gasket in the way to have a good squish
Old May 28, 2012 | 12:44 PM
Moonstone Mart's Avatar
Moonstone Mart
Shame about the moonstone saph, it looked lovely.
Old May 28, 2012 | 12:54 PM
Less.'s Avatar
Less.
having a mid life crisis
So the engine going in another Sapph then ?
Old May 28, 2012 | 03:03 PM
NoNoCos's Avatar
NoNoCos
Yes
Old May 28, 2012 | 06:09 PM
sygjim's Avatar
sygjim
c est beau ca mon nono
Old May 28, 2012 | 06:29 PM
sygjim's Avatar
sygjim
very nice my NoNo
Old May 29, 2012 | 10:48 PM
Shame about you other saff.What a mess it looks
Old May 29, 2012 | 11:25 PM
Tarren's Avatar
Tarren
Look foward to seeing this progress fella!
Well done
Old Jun 10, 2012 | 05:28 PM
NoNoCos's Avatar
NoNoCos
Little up, I forgot last time to post my crankshaft pulley balanced :
And last weekend, as I started to change the fuel pump loom, I finally dismounted all the inside to clean everything and put back a lot of parts from my old cossie... (dashboard, trims, seats, headliner, etc...)
It was also a good time to remove the alarm, and to remove all the bad connexion on looms made by the old owner
Inside picture with everything fitted soon...
Old Aug 11, 2012 | 06:58 AM
sygjim's Avatar
sygjim
nice work my nono
Old Aug 11, 2012 | 07:02 AM
whizzisat114's Avatar
whizzisat114
Im sure theres a thread in general car discussion about those g19 baffels failing.
you might want to have a read before running it in your engine.
Car looks gorgeous in that colour
Old Aug 27, 2012 | 03:16 PM
sygjim's Avatar
sygjim
any news ?
Old Dec 30, 2012 | 05:04 PM
NoNoCos's Avatar
NoNoCos
Wink Rear Beam
Right now we have some nice winter days over there, it was a good time to work on the rear beam in order to dismount it totally to get a 6 degrees one, and also a good occasion to clean the underneath to check if there is no rust, and then to have to something nice to work on ! The result is not too bad for a 20 years old lady, and I'm pretty happy about the preservation state...
Here is some pictures :
Before :
After :
Soon, some more pictures
Old Dec 30, 2012 | 05:08 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Could you not have pulled the dent out the old one lol! I bet you was gutted must have been a hard whack! Good luck with the new build
Old Dec 30, 2012 | 05:11 PM
blimey that must have hurt
Old Dec 30, 2012 | 05:54 PM
wattie's Avatar
wattie
It seems sierras bend just a tad when they get a hit at the back! Good luck with the new one
Old Dec 30, 2012 | 07:21 PM
jamie's's Avatar
jamie's
looking nice,
quick question- do all lhd saphire cosworths have no electric windows in the rear?
or is there differant spec levels like the old rs turbo's etc?
Old Dec 30, 2012 | 09:22 PM
NoNoCos's Avatar
NoNoCos
As I know there was electric windows on all 4wd lhd and never on 2wd...
Old Dec 30, 2012 | 09:49 PM
jamie's's Avatar
jamie's
thanks, i never knew that
Old Dec 31, 2012 | 08:02 AM
jason_nike's Avatar
jason_nike
Car looked lovely in first few pics, then the smash was a shock.
Good luck with finishing.
Like the thread title
Old Apr 22, 2014 | 04:44 PM
NoNoCos's Avatar
NoNoCos
Long time I haven't had the occasion to write a bit in here...as I'm not all the time at home, it's hard to go ahead. But I've been recently able to work on, so here some pics, more will come.
Parts back from anodising :
Working on gauges loom :
Gauges from :
Old Apr 22, 2014 | 05:12 PM
ital_cossie's Avatar
ital_cossie
post more pics!!!
Old Apr 27, 2014 | 10:08 AM
NoNoCos's Avatar
NoNoCos
Many parts from engine has been sanded then black coated except the throttle body and the fuel ramp, received as it :
And following the 65mm throttle body supplied by MK Motorsport, it tooks me a while to get it, but the job is awesome, thanks to MK !
Old Apr 27, 2014 | 08:32 PM
costina's Avatar
costina
Live long and prosper!!
I'm liking the throttle body very nice 70mm?
Old Apr 28, 2014 | 11:54 AM
NoNoCos's Avatar
NoNoCos
It's 65mm inside and take the original holes
Old Apr 28, 2014 | 07:19 PM
costina's Avatar
costina
Nice did it cost much?
Old Apr 28, 2014 | 08:29 PM
NoNoCos's Avatar
NoNoCos
Not sure, I bought it a while ago, but there is some info in here :
https://passionford.com/forum/trader...le-bodies.html
Old Apr 30, 2014 | 12:31 PM
NoNoCos's Avatar
NoNoCos
I had to rebuild fuel lines, as they were both mashed. I found a local supplier able to do the same one, and also ask the reproduce the plastic ones, here a pic of the job done.
Old Apr 30, 2014 | 10:10 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Very nice, cant wait to see this one go back together!
Old May 3, 2014 | 04:21 PM
NoNoCos's Avatar
NoNoCos
I finally installed gauges into the car, I had them since a while.
What I did, is to take the dashboard lining from the old one, cut a part and past it onto the gauge mount plate, I'm pretty happy of the result.
Old May 3, 2014 | 07:37 PM
little bram's Avatar
little bram
looking good great work
Old May 4, 2014 | 09:43 AM
NoNoCos's Avatar
NoNoCos
Thanks mate
Old May 4, 2014 | 10:29 AM
turbotrev's Avatar
turbotrev
Coming on lovely mate!
Where are the pulleys from out of interest?
Cheers Paul
Old May 4, 2014 | 03:59 PM
NoNoCos's Avatar
NoNoCos
Actually this is Kent cams pulleys that I bought red, and I brought it for anodising, gives a cool finish.
Old May 5, 2014 | 10:04 AM
Its looking really smart. Nice attention to detail too.
Old May 5, 2014 | 12:56 PM
doctor stavros's Avatar
doctor stavros
AMG C32
Love the gauge pod using proper dash
Old May 23, 2014 | 12:16 PM
NoNoCos's Avatar
NoNoCos
Hi mates,
I was thinking about to remove the ABS block and then install a pedal box with master cylinders for front and rear. I have seen the one at burton, but I don't know if it does exist others one ?
Which solutions have you fit ? If you do have some pics that would be great !
Old May 24, 2014 | 11:32 AM
Mondi-DZK's Avatar
Mondi-DZK
Very nice, it looks like it's original.
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
arfurski
Sep 26, 2015 10:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
