Body Shell
Old Feb 25, 2011 | 12:10 AM
daveo91's Avatar
daveo91
Default Body Shell
Is the mk5 ford ecsort body shell the same as the mk6 ford ecsort body shell thats is with every think striped out
Old Feb 25, 2011 | 12:13 AM
Joshy's Avatar
Joshy
Dreamer
no, there similar but most of the outer panels are different.
a bit like the difference between a mk3 escort and a mk4 escort, or a mk1 escort and a mk2 escort.
Old Feb 25, 2011 | 12:15 AM
daveo91's Avatar
daveo91
thank you so if u wanted to theres a bit of weiding to do lol
Old Feb 25, 2011 | 12:23 AM
Joshy's Avatar
Joshy
Dreamer
well yes, but why would you when you could just find a car with the body style you want?
it may be worth it when the cars rare like converting a mk4 to a mk3 but its pointless for the newer models.
but in theory your right, you can
Old Feb 25, 2011 | 12:31 AM
daveo91's Avatar
daveo91
yhh i wanna to it do my ford escort mk5 because my nan give me the car when she passed away so now i no that its a bit of welding i like the look of the mk6 but dont wanna change the car
Old Feb 25, 2011 | 12:44 AM
Joshy's Avatar
Joshy
Dreamer
i always thought the mk5 looked better but each to there own lol
Old Feb 25, 2011 | 07:54 AM
cossiedevil's Avatar
cossiedevil
To change the car over to from mark 5 to mark 6 changes needed are rear end of the quarter panel where the back light sits in has to be changed to mark 6 you can buy this new.Then you need a mark six bootlid.Then the doors as the handles will be mark 5 mark 6 have a bubble handle.Then the front mark six bonnet to be fitted and headlights the slam panel is different to let the mark 6 lights fit up then you need the grille and bumper also mark 6 wing mirrors.And if you want a total mark 6 look the fuel filler would have to be changed
Old Feb 25, 2011 | 10:26 AM
atm's Avatar
atm
you dont need full rear quarter panels, its just the little infill plate that sits below the rear light between the bumper you need for them, theyre only cheap.
similair story with the front panel, theres just a little plate spot welded on which you can buy seperately, or just unpick them from a mk6 in the scrapper, plenty about. That supports the mk6 headlights.
but as cossiedevil has said about the filler cap being different, the mk6 hole is bigger, you would either need to cut out a section from a mk6 or buy a repair section for the mk6 filler (i know they do them for the mk5, but not sure about 6?) or the third option is to change the full o/s quarter panel for it.
Old Feb 25, 2011 | 12:35 PM
daveo91's Avatar
daveo91
thank u all for this that is going to help me a lot
Old Apr 24, 2011 | 01:35 PM
martin1984's Avatar
martin1984
Default shell advice
are the floor pan the same and the inner sills on the mk5 and mk6 escort or difarent
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fil
Sep 30, 2015 12:08 PM
