please help! draining battery?
Old Jun 16, 2010 | 05:20 PM
moondust-saph's Avatar
moondust-saph
moonstone-saph
Default please help! draining battery?
my cosworth battery keeps discharging, the battery is new and after being left for 5 days its dead, charged it up a few times nad it keeps happening? is there any common faults for this to happen?
many thanks
Old Jun 16, 2010 | 06:29 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Really could be anything mate.
Easiest way to check how much current is being drained is to disconnect a battery terminal and connect in an ammeter between the battery and terminal.
Lock the car up as you would normally (if you have an underbonnet switch for the alarm, this will need to be held down or the alarm may not set right and give an iffy reading), look at the reading on the ammeter, it should read under 0.1 ideally. If it's any higher, then start pulling fuses one by one (putting them back after!!) and see if the current drops. If it does, that's your faulty circuit.
If pulling fuses makes no difference, try disconnecting the alternator, starter motor etc...
Where abouts in Hertfordshire are you? I'm in Watford, so if you're not a million miles away I don't mind having a look at it for you if you want?
Old Jun 19, 2010 | 02:21 PM
moondust-saph
moonstone-saph
im in borehamwood matey would be apreciated if you could come and see it, mot is tuesday so fingers crossed
Old Jun 19, 2010 | 04:14 PM
RichieST's Avatar
RichieST
Have you checked things like boot light is going off when boot is shut etc?
Old Jun 19, 2010 | 04:41 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
probably a dodgy earth or couple of shorted wires on a low current circuit!
is your sig big enough??
Old Jun 19, 2010 | 05:00 PM
rik-rs's Avatar
rik-rs
alternator could be fooked, i had a saph that would drain the battery after a few days, was the alternator.... had ammeter between battery and terminal was drawing around 2 amps if i remember, until i undid the alternator, bingo..
could be that..
Old Jun 20, 2010 | 12:14 PM
coswurv's Avatar
coswurv
Might be a boot lock issue beings yours is missing in the photo, might be putting the boot light constantly on.
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
