Ok so it's not a ford...
#41
cheers, no reason why it shouldn't, being built with realistic power, not going crazy FWD. will eventually get LSD too, loved it in my old car. just a case of getting some funds together!
#42
Gave the car the bufty of its life today. all washed, clayed,polished and waxed with dodo juice hard candy, came up really well and looks 10times better in pictures!
#43
decided it will be going to jabbasport to be mapped, seem the most knowledgable and has told me what else i need for the build, every other company didn't seem to have a clue with hybrids
#44
little job, old badges were looking haggered from age so replaced them with some fresh oem ones, genuine parts, wasn't paying Ł15 a piece from skoda though! its a Skoda FFS. Ł6.50 ebay
old vs new
old vs new
#45
s3 maf here, have modified the air box to fit, will need to squeeze it into the k03s tip but it will go with a bit of wrestling me thinks!
#50
still standard i presume, aint been mapped yet so obviously not getting the full potential from the mods
Exhaust is on, sounds just right! nice deep grumble similar to that of an s3, not intrusive, and still quiet in the car!. Performance wise it feels better through the midrange, the cat was probably choking the turbo a bit mind. Will get some underneath shots when i can, quality is perfect! can'y thank jeff at pipewerx enough!
#52
Managed to squeeze the s3 maf into the K03s TIP with some gentle persuasion....took me about 2 hours of wrestling with a bit of heat, a file and some lube to get it in mind!
bought a few clamps for here and there, mainly where the maf goes in, dont trust the jubilee clips i have, and its a bitch finding them so big and the shape deforms etc so got some of these
stuff from forge turned up too, so will bin off the secondary air system when i get a chance!
#53
Got a few pictures of the back end quickly, was piddling down so really couldn't be bothered. may raise it a bit into the recess, still haven't decided.
other goodies arrived too
S3 (larger) maf
blanking plate
Spring to handle more booooooost after map
wet video
http://www.youtube.com/watch?v=H2hADvubFdA
S3 (larger) maf
blanking plate
wet video
#54
so...jobs today, removed the secondary air pump that runs for the first 90 seconds of starting and makes the missions better...well cause theres no cat there....
sh*te out
Undersealed the car and got a couple of pics of the decat
also made a better video with the camera mounted in one of the front grills
http://www.youtube.com/watch?v=dRzWfOjE4h8
sh*te out
#55
removed some more uneeded stuff from under the bonnet, all simplified with a pipe from the dumpvalve to the inlet. going to order a newsouth inlet gasket to stop it transfering heat from the head too. whilst i have the inlet off think i'll be painting it crackle black, thats the theme ill be going for under the bonnet me thinks with a few other things to match.
put resistors in place of the sensors and no codes as of yet
#56
Turbo has been collected today by CR turbos, should be back by next weekend hopefully. Will get it bolted on asap.
also ordered a Newsouth inlet gasket, stops heat transfer to the inlet to give lower inlet temps, have heard good things about them and a member was selling one cheaper so thought what the hell, inlets coming off for a lick of paint either way so!
#57
Stubby aerial, reception is crap but don't listen to stereo anyhow...
de-wipered the rear, never used it anyhow
had it on the rollers today too
graph...
nice base to go from for future mods, which by the way has started, turbo is at CR being hybrided
borrowed some signs aswell in typical scouse fashion....
graph...
#61
Didn't get chance to take many pictures with the turbo off, focus was on getting it done.
Turbo off
bolted back on exactly as the old one came off. Haven't fitted injectors till it gets mapped so i can drive down. Had a run locally to chack for leaks and so far so good, not getting mapped till next week so i can make 100% sure everything is right. Boosts a little higher due to garrett actuator so i haven't been driving as normal, last thing i want is a melted piston. spool up is slightly louder on the new one due to it being unsilenced but nothing major.
Turbo off
#62
Decided to tidy up behind the plate today, rather than having wonky holes decided to go for one big one.... angle grinder and a file...came out pretty well i think, will be hidden by the plate and only taken off for track etc so not majorly fussed, may even try a smaller plate offset and open it up a bit more...
Engine cover needs modding to clear the dump valve...but heres the engine bay so far
Modified recess in front with no plate
and how she sits
and how she sits
#64
Was a long day yesterday, Up at 430 to get to Jabbasport in peterborough for 9am from liverpool.
wakey wakey
Average MPG on way
[img]http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs569.snc3/31058_10150189167895072_735470071_12555483_3006251 _n.jpg[img]
light entertainemt on the way
Figures
MPG way home....
Fly fest
End time
Modified the plastic cover to fit over the dumpvalve too
Overall really happy with the figures, drives like a totally different car. under 3k drives as it did and returns good mpg. then over 3k to 7400 (raised the rev limiter) pulls so hard and sounds mental. Grips really well in the dry too which is what i was after, useless power if it only spins up. Boost is at 1.4 then settles to about 1.2
Big thanks to Jabbasport for mapping it, bunch of friendly guys, great premises too. Sorry no pics on the rollers as they dont let public in there i presume for health and safety.
Spec list is as follows
Octavia VRS
K03s hybrid (CR turbos) with garrett actuator
Forge front mount intercooler
Pipewerx turbo back 2.5" system.
Bosch green injectors
Walbro 255 fuel pump
Derestricted air box with pipercross filter
Forge 007p
Silicone TIP
N75 and other crap removed
S3 maf
Modified crash bar and bumper
Next things to come with be ARBs porsche brakes as i dont think these will be up to track abuse and possibly some coilover....we'll see
wakey wakey
Average MPG on way
Figures
MPG way home....
Fly fest
End time
Octavia VRS
Forge 007p
Silicone TIP
S3 maf
#66
yeah over the moon buddy, drives really really well. looked into a high flow mani but to be honest the price of them put me off the idea of one for the gains assosciated.
#70
quick video, will get a better one when i've fixed the boost hose that keeps popping off...
http://www.youtube.com/watch?v=cyuJ5Kg0-GM
#72
Few last pics of it on the BBS rims, yup they look good on the car but just been fancying a change of styles, have lots of people already interested in the wheels with a provisional sale already so no point asking.
LCR splitter fitted too to change the front a bit.
peak at new rims, some people will already know what they are...
New wheel bolts expected during the week so wheels should be fitted for the weekend, would have been on now but FK decided to send me the wrong ones....buggers.
#77
pics do this thing no justice!! really has come along so much and it was a spanking mint low miler one to begin with!!
Can't wait to dust it in the olop next summer
#79
Firstly....i am aware it needs more lows, coilovers are the next purcahse. And yes the old wheels did look great but i felt it was time for a change. All opinions welcome as always.
