little tidy up job
bought this today
used to be a bunus then it was 3i now it rs turbo clean old shell, no real rust on it, few scabs popping up but im keeping away from that stuff jobs to do replace loom (got 1 with a cat 1 ready to go :top: ) rs carpet and other trims mint up the seats replace suspension (most of its loose or finger tight :cry: ) fit ecu's up tidy the bay up get some propper lamps find a better silver boot mot her up wont take a great deal to mot once the looms done, at the moment it does alsorts of strange things and very little works got it started to check it over and the guy haddnt refitted the oil return so we covered his grans drive in oil :cry: seems to run very well tho with its mongoose pipe and bits here and there, hopefully its chipped too going to have fun sorting the sheared off seat bolt stubs from the floors :wall: will make a nice thrash about/track/cheap insurance car for some1 when done :top: https://i61.photobucket.com/albums/h.../Image0004.jpg https://i61.photobucket.com/albums/h.../Image0002.jpg https://i61.photobucket.com/albums/h.../Image0095.jpg https://i61.photobucket.com/albums/h.../Image0001.jpg 1st jobs done, do away with that rope bonnet pull :cry: and fitted a decent 1 :top: |
do like a silver escort... :top:
:cool: :cool: :cool:
Brian |
ooooh i do like a silver one :top:
QUADS ARE OUT, FITTED STD LAMPS 1 SIDE, BUT CAN I BOLLOCKS FIND THE BOLT I NEED FOR THE OTHER SIDE :cry:
fukcing caps :wall: ive got a tub full somewhere :top: it'll get there when it stops raining still stripping this 1 down, it does still run too :cool: https://i61.photobucket.com/albums/h.../Image01p3.jpg |
getting some jobs done
interior is all out showing 2 bits needing weld, on inner sills, never would have failed an mot on, its well hidden, but ill sort it, neither touch the outer sills and the seat mount has a snapped bolt so will sort that out old looms half out floors are very clean too much rain to get much more done |
im loving the welding, ok so its not new floors and inners but were not talkin classic car here so its being kept sensible
nothing the mot man would have noticed as it didnt show from the underside but i like welding so found as much as i could :top: the seat mount was a bitch as it had been welded from the underside before but was well knackered above and had a sheared bolt but i cut the same parts from the rs im breaking, drilled the spots so i only welded in the reataining/strenthening section, could put some really fat people in the drivers seat now :top: https://i61.photobucket.com/albums/h...erturbo001.jpg https://i61.photobucket.com/albums/h...erturbo002.jpg https://i61.photobucket.com/albums/h...erturbo003.jpg https://i61.photobucket.com/albums/h...erturbo004.jpg just the rear sills next, they could scrape an mot but ill just sort it everywherre else is mint, rear chassis rails are perfect :cool: |
still cracking on, its got its new loom, 88 spec interior, some painted up and shiney bits, needs a release bearing and the top ends a bit rattley so may sell it as a going concern as i havent time to do much else :(
ahh well see how it goes on pistonheads if it stays ill stuff my cammed up spare engine in for a quick fix and sort a cam kit on this engine at some point its all on teh key and built up now tho :cool: https://i61.photobucket.com/albums/h...o/Image021.jpg https://i61.photobucket.com/albums/h...o/Image022.jpg https://i61.photobucket.com/albums/h...o/Image023.jpg https://i61.photobucket.com/albums/h...o/Image024.jpg https://i61.photobucket.com/albums/h...o/Image025.jpg |
:top:
what are your plans with it |
Your seats are in the wrong way round :blabla:
winder in the middle ;) |
of course, saves wear
i always put em in backwards |
:top:
looking good :top: :top: :clap:
i am in the middle of do in a silver one it is mint
© 2024 MH Sub I, LLC dba Internet Brands
