rwd mk3
Old Mar 16, 2007 | 02:56 PM
luke mk3rwd's Avatar
luke mk3rwd
Default rwd mk3
been searching the net on info on rwd mk3 escort conversions. the furthest i've got is realising the g3 escorts (genesis kit) run with mk2 running gear but the info i have is short on specifics i don't know if they use the whole mk2 floorpan or thet just fabricate a tunnel. i have thought about using sierra running gear as mk3 is also independent rear suspension. would be chuffed if anyone out there could end my frustration and give me some info. also would conversion also be poss on mk4+5
Old Mar 16, 2007 | 03:10 PM
stoo2000's Avatar
stoo2000
anything is possible if you have the money mate,
regarding the MK5 escort im having one done here (orion really )
https://passionford.com/forum/viewto...246092&start=0
As said its alot of cost, but should be worth it.
Old Jun 26, 2008 | 01:18 PM
rwd_fiesta's Avatar
rwd_fiesta
Just to clear up a small error in your posting. The G3 was a Gartrac built conversion (a rally prepared version of the later road going G6). The Genesis conversion was originally marketed by Rally Design if I remember correctly and was based on a kit supplied in kit form or complete shell. It used fresh steel for the floor, 4 link boxes, etc and was designed to take all Mk2 Escort group 4 parts including steering column. It sported standard width arches as standard and I believe a MK2 escort dash panel was specified on complete shells!?
The Gartrac G3 used many specially built/adapted components as supplied by Gartrac and used a Mk3 dash panel and modified steering column.
As an addition, sierra floor/inner wings work beautifully on the MK3 and 4 Escort. Steering column, heater, etc, etc, can be engineered very well. Although this has universally been adapted by many companies and extended to many other models, Gartrac have carried out this conversion to customers own shells. Talk to them. (Not cheap but the best)
Cheers.
mk3ste
Oct 17, 2021 10:09 AM
turbotrev
39
Apr 17, 2016 09:03 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
