Vauxhall Vivaro van on BMW 18" alloy wheels !!!
Originally Posted by R4N S S
dont the wheels on vans have to be load bearing?
Just wait untill someone posts a link to this on the BMW forum - hell will brake free
ok,
what you need is Standard BMW alloy wheels.
Spigot rings 72.6mm to 71.1mm (i had to have these made!)
14mm Vairy centre (wobbly) wheel nuts
16mm metal drill bit.
a bmw stud pattern is 120 x 5, a vauxhall Vivaro stud pattern is 118 x 5.
The wobbly wheel nuts correct this. (they will correct any 2mm vairation)
Bmw spigots are 72.6mm and a vivaro spigot is 71.1mm
The spigot rings correct this.
16mm drill bit is for the hole in the alloy what the bolt goes through.
Thankfully i didnt have to drill but it needs 16mm for the wobbly wheel nuts to ..erm... wobble into place.
The spigot ring is essential for the positioning of the alloy on the hub. Without the spigot rings im told there would have been serious judder on the steering as the wobbly wheel nuts wont centre the wheel like on a normal hub.
For all of you talking about my tyres, thanks for your concern, but the tyres are XL LOAD and i dont carry much weight in my van anyway.
I could have put 20" X5 alloys on, but i really couldn't afford the tyres every 6 months. My alloys are 18" with 225/40/18 tyres on. cheap as chips tyres. well, compaired to 20's they are.
For the people on the BMW forum, i will change the centre caps for vauxhall ones and put a bit of tape over my M badge.
Oh yeah, SNP and Stavros, this is my own van not a company one, so i want it to look the part.
Originally Posted by brizie
mate it aint the tyres its the actual wheels themselves that have to be up to the weight and i very much doubt they are
http://www.performancealloys.com/com...loy_wheels.asp
read the top left hand box, looks okay but would have been better with 19" M3 wheels
Originally Posted by GARY1978
it looks like something dale winton would drive his bum boy around in
i bet that handles like a pig
right.
a cars kerb weight is usually about 1500 to 1600 kg's. My vans kerb weight is 1750kg.
That weight difference is about the same as a fat bloke.
so i ask you, do your alloys snap in half when you give a fat mate a lift ??? Has anyone ever had an alloy snap when loading up a car with thin people ??? Have your alloys ever snapped when you go camping and your cars loaded up with gear ??? Do show cars snap alloy wheels when they're loaded up with ICE, Fibreglass, leather n whatever else goes in it ???
If i had a flatbed van and i was loading it up with bricks and cement, i would see your point, but as it is, its ok.
Originally Posted by Rich_bloor
right.
right.
Not wanting to add to the negativities but on the transit forum (yes I belong to that but its not that bad) they say the police take a dim view of un load rated wheels. However in a normal van I think its unlikly you'd draw their attention and they arnt gonna think of that in the first place . Looks good though I think, better with vauxhall centre caps like you said
right.
Full credit to you for trying something different, looks good mate!
As for them not being strong enough , a 5 series with 5 people in it will be heavier than that van with a few bits in anyway so theres no problem there at all. I can safely say ive seen bmw's full with passengers without the wheels crumbling to pieces so no need to worry id say.
