cam timing
Old Jan 3, 2006 | 10:40 PM
boost mad's Avatar
boost mad
Default cam timing
on a 2wd cossie. may fit my vernier pulleys this weekend, but wanted to no @ what in degrees are the cams as standard
cheers
Old Jan 3, 2006 | 10:42 PM
Ian M's Avatar
Ian M
110 degrees both cams.
Old Jan 3, 2006 | 10:44 PM
boost mad's Avatar
boost mad
cheers, and the markings on the verniers shud be at 0degrees aswell then
Old Jan 3, 2006 | 10:46 PM
Ian M's Avatar
Ian M
i dont know how accurate the markings are. my verniers dont have them. we used a dti to time mine up.
Old Jan 3, 2006 | 10:50 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
it all changes if the head or block has been faced.. timing it up on the standard settings is only a starting point
Old Jan 3, 2006 | 11:24 PM
boost mad's Avatar
boost mad
thats what i was going for. gona start from original marks etc and then change until i have the cash to get it set up
thanx for teh help
Old Jan 4, 2006 | 06:45 AM
GARETH T's Avatar
GARETH T
yes you do get ignition dwell angle,, but he aint talking about that here, as he has a efi engine car
remember the pistons dwell at TDC for a few degrees,, and this is what he is on about (i think)
cam timing is something i dont like explaining,, as i get my words in a muddle
if you are running fiesta efi you dont need too worry about engine phase so here goes (so too speak)
remove all rocker arms ( you dont need to do this but it could save you from bending a valve,, better too be safe on your first time)
set pistons too tdc, remember that the pistons dwells at tdc so to do this you need to measure the angle the pistons seams too stop, and seems to start moving again, half this movment and you will have a true tdc, i use a bore gauge for this (which i know is tricky on a cvh)
now once you found your try tdc, fit you timing wheel too the crank and make a pointer so that it points at 0 degrees!
now read you camshaft information and find that part where it tells you full lift for the inlet and exhaust angle? (115 degrees or there about)
turn your engine too the full lift figure (guessing 115 degrees before TDC for the exhast full lift,,, 115 degrees after TDC for the inlet cam profile)
so now the crank is set of your cam timing figure say 115 degrees BTDC, place a DTI (dial test indicator) onto the exhaust lifter of number one cylinder (furthest from the gearbox),slacken bolts on vernier, now move the camshaft till you get full lift (so the lifter is as far up as it will come, using the DTI to measure this) remember the lifter will also have a dwell period so this needs too be halfed! tighten vernier!
place DTI onto inlet lifter for number one, turn crank and see if you get full lift at the right crank angle!
i check and check a few times! do not turn the crank anticlockwise when turning the crank too gain your full lift crank angles as this will put the slack side off the belt on the wrong side of the pully system and gain you inaccurate camshaft timing
if you are unsure of anything, dont do it, as engines are expensive,, and the damage you can cause by doing this wrong is sickening
i know there is other ways of doing it, (like measuring what angle full lift happens and then using the indicators on the verniers too turn too full lift, and also the method of measuring valve overlap, even balancing valve overlap on some engines) but i thought this was the simplest way
remember the cam only turns once for every 2 turns of the crank (crank phasing)
ummmm think ive covered it
i wrote this a little time ago on another thread
https://passionford.com/forum/viewto...ght=cam+timing
may help you a little more
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
