Finis Code Check Please?
Old Dec 23, 2005 | 06:02 PM
FletchCossie's Avatar
FletchCossie
Default Finis Code Check Please?
Has anyone got Microcat so they can check a finis code for me please??
Ive got a problem with the heaters in me Esc Cos at present. You turn the heaters on internally and they don't blow! I assumed it was the switch, so tried a new one on it and still had the problem. Spoke to Ford's today and they ordered me a new heater resistor... The one I got from them has finis code 1652108 and part # 88GG 18B647 AA and my old one has the part # 89 BG 18B647 AB, so obviously I have the wrong one or have they upgraded it?
Ive tried the new resistor and still have same problem, but this maybe due to it being wrong? as the old one has more connectors on the top.
Can someone please check to see which finis code they have on MicroCat so I can track one down tomorrow?
Old Dec 23, 2005 | 07:48 PM
DOO's Avatar
DOO
1652108 (89GG 18B647AA) is the only one listed for an escort and should be the correct one.
are you sure yours is (89BG 18B647AB) and not (89FG 18B647AB) ???
if it is you will need 6184971 but thats listed for a mk3 fiesta ???
Old Dec 24, 2005 | 03:53 PM
FletchCossie
Doo, Ive got part # 89GG 18B647 AB here and the prongs are the same, but it doesn't have the mounting bracket and its bigger than my original??
My original one is definately 89BG 18B647-AB
The internal fans don't work with this one either, so Im thinking it maybe the other switch as that has the on/off function attached. Has anyone got a wiring diagram so I can test wires???
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
