changing actuator,help please
Old Nov 1, 2005 | 07:34 PM
the benno's Avatar
the benno
Default changing actuator,help please
had my s1 rolling roaded and they said boost peaked at 15psi
then dropped to below 10psi ,it is a -31 but a bit weak now i think,
if i put a new -31 on is it a case of measuring bar against old 1 to get the boost right till i can get it back on rollers
cheers in advance
Old Nov 1, 2005 | 07:41 PM
Alvyn's Avatar
Alvyn
Default Re: changing actuator,help please
cheers in advance [/quote]
IF IT'S WEAK THEN IT WONT BE THE SAME AS A NEW ONE M8!
so set it low till u have it set up properly
Old Nov 1, 2005 | 07:47 PM
CosRush's Avatar
CosRush
If you've had it rolling roaded and the fueling was fine throughout, stick on the new -31 and set it at half a hole pre load......
road test it and then keep adjusting the rod until you get back to the requirted held boost as before........
sorted
Old Nov 1, 2005 | 08:52 PM
ballin's Avatar
ballin
^^ what he said. just make sure you aren't using a TIM gauge etc
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
