help needed....suggestions please
Old Jul 7, 2004 | 09:03 AM
cossymad's Avatar
cossymad
Default help needed....suggestions please
Ok car won't start.
It turns over fine but will not fire up.
I have tried the following so far.
Fuel pump- buzzes as usual as on start up
Fuel cut switch checked.
Multi plugs under bonnet checked- well wiggled!
ecu connection chcked
chip checked for connection too.
petrol checked..........
any more???
I'll be back in 5 minutes
Old Jul 7, 2004 | 09:06 AM
jamieslittleracer's Avatar
jamieslittleracer
yeh cut a hole in the footwell and flinstone it around
no hun im sorry my pajero wont start either so any ideas would be great.
katie x
Old Jul 7, 2004 | 09:07 AM
Ragtop's Avatar
Ragtop
A Melter or fallen-off CPS does that... The pump primes, but without a 'revolution' seignal, the injectors won't fire..
HTH's..
Luv
Chrisie...
Old Jul 7, 2004 | 09:11 AM
cossymad's Avatar
cossymad
That is new so I'll check it ain't fallen off
Old Jul 7, 2004 | 09:39 AM
Jim Galbally's Avatar
Jim Galbally
this the small turbo EECIV one?
Old Jul 7, 2004 | 12:49 PM
cossymad's Avatar
cossymad
Yes Jim.....the reliable one
Old Jul 7, 2004 | 12:52 PM
Stu @ M Developments's Avatar
PassionFords Creator
Unplug the chip.
Old Jul 7, 2004 | 12:58 PM
cossymad's Avatar
cossymad
Will do....hold on
Old Jul 7, 2004 | 01:24 PM
cossymad's Avatar
cossymad
pull out chip....did n't start, so plugged it back in....and it still didn't. Any other suggestions?
Old Jul 7, 2004 | 01:26 PM
Jim Galbally
can you check for a spark on EECIV or does it use individual coils per cyl?
Old Jul 7, 2004 | 01:27 PM
zvhturbo's Avatar
zvhturbo
Check your fuses.
Old Jul 7, 2004 | 01:42 PM
cossymad's Avatar
cossymad
It does use coil packs, but you can still check for a spark- I'll do that later, I don't think my missus will be too impressed with checking the spark!
I'll get her to do the fuses though.
STU can you use an ECU with a COSY tare code, on a car with a ANTI ECU if so will it start as I could swap ECU's to see if I have frazzled another one
