sensor postioning
Old Oct 4, 2005 | 11:10 PM
rapidcossie's Avatar
rapidcossie
Default sensor postioning
where is the best place to fit this sensor on my 2wd saf?
want a true as posible reading.
have got a sensor adaptor so i can cut one of the water hoses and fit it inline.
was thinking about drilling the thermostat housing but surely the water before the stat is cooler than the water in the engine itself?
what way does the water travel round the system ?
cheers
euan
Old Oct 4, 2005 | 11:11 PM
rapidcossie
my understanding is that water comes out the bottom rad hose on the drivers side of the car and into the engine under the turbo where it stays(in the engine) until it reaches 88 deg then the thermostat opens letting the hot water out and into the top of the rad on the right hand side.
the fans only run when the fan switch senses that the water temp in the rad is above a certain level.
the fans and thermostat are not linked in any way and operate independantly.
so best place to fit the water temp sensor would be in the hose going in to the engine under turbo??
Old Oct 5, 2005 | 05:15 PM
rapidcossie
up
does no one know?
Old Oct 5, 2005 | 05:30 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i placed my temp gauge sensor in the top hose part of the thermostsat - never raises above 85 celcius cruising and 90 when driving hard
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
