knocking on ecos........
does anyone have any idea's where this knocking noise is coming from
really starting to piss me off now :wall: right i have a knock if you lift off the throttle to quick or you slip the clutch then come off the clutch too quickly, or press the throttle too hard after coasting. get the same :cry: i've replaced gearbox mount engine mounts the car now has a full poly bush kit can there be movement between the transfer box and the main drive from the engine???? any input to my problem would be great thanks in advance :top: dene;) |
what bout zorst hitting the drive/prop shaft?
Na not the exhaust. its solid, its quite a harsh noise :cry:
I've had a similer problem,and it was the chain in the transfer box.Changed it and no probs now :cool:
just a note about the front prop hitting the downpipe, if you have not heard it before, you would swear that the engine was gonna drop out and the whole exhaust system come off under you , with a stainles pipe it seems to amplify the noise 100 fold, then you get underneath expecting a huge rip in the side of it, and there is a mark just skimmed smaller than the size of you rlittle finger nail on a bit of the downpie you cant even see :), its like a loud metallic clanking sound :(
mine was doing this, was the down pipe catching on the bulkhead/inner wing :wall:
Its not your front prop is it ??
i'd say exhaust... mine's hitting atm, and it's knocking really loudly.
well if i move the front prop with my hand is does sound a bit noisey :cry: prob could be the transfer box chain :cry: is this hard to do??
there is always a bit of backlash in the front prop that doesnt sound too clever,
© 2024 MH Sub I, LLC dba Internet Brands
