over heating please help
Old Jun 18, 2004 | 12:42 PM
c6mby's Avatar
c6mby
Default over heating please help
well i dont know what to do now my series one is still over heating.
ive changed the thermostat hoseing the thermostat put new seals on.
replaced the hoses
put a new(ish) rad in
new fan
new temperature sensor
new water pump
flushed the engine thro 3 times
new gauge well extra gauge
but still it gets very very hot and over heats even if im driving on the motorway witht the fan on it will over heat has anyone got any other ideas?
i have checked the rad for cold spots and it seems fine i have bleed the system again fine the gauges seem to be working but i put a new temp sender in anyway.
i really dont know what to do now.
is it possible the head gasket may have gone?
as the car runs fine and is no sigh of oil in water or vice versa.
any help would be much appriciated
ive also given it an oil change with new filter and cooler
regards
sam
Old Jun 18, 2004 | 01:06 PM
KSA-Cossie's Avatar
KSA-Cossie
IS THE TIMING SET CORRECTLY?
Old Jun 18, 2004 | 01:13 PM
Lemon S2's Avatar
Lemon S2
Have you got a GRS or Pace I/C in there, if so I'm having the same probs. No gone to the same extent as you yet but will getting along those lines. Managed to split a hose which was sort of bodged on just to get me home and the temp hardly moved from the bottom so I'm very confused as to the probs with mine.
If you do have the GRS or pace are you running one fan or two. I've got only one at the mo but am seriously thinking about getting a second.
Sorry can't really help but would also like to know peoples ideas.
Old Jun 18, 2004 | 01:18 PM
Jim Galbally's Avatar
Jim Galbally
are any of your water hoses HIGHER than the header tank?
Old Jun 18, 2004 | 01:43 PM
c6mby's Avatar
c6mby
nope none of the hoses are higher than the header tank
in running 2 2wd cossie cooolers so the rad has exellent airflow.
Old Jun 18, 2004 | 04:39 PM
c6mby's Avatar
c6mby
anyone else i really do need some help here peeps
Old Jun 18, 2004 | 04:52 PM
EscortWRC's Avatar
EscortWRC
head gasket ???
Old Jun 18, 2004 | 04:55 PM
NUTS RuS's Avatar
NUTS RuS
Is the water pump functioning okay ? I know its new - but is it working.
What happens if you remove the thermostat altogether ??
Old Jun 18, 2004 | 10:53 PM
c6mby's Avatar
c6mby
how can i cheack the water pump??
im taking the thermostat out tomoro to see if that helps
any other ideas??
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
