Excel Gurus
Old Apr 27, 2005 | 01:51 PM
Rhys's Avatar
Rhys
Default Excel Gurus
Right then, any one got an idea how i would right a forumla for this?
Drilling cost: for rock thickness below 5 metres $400,000
from 5 metres to under 9 metres $600,000
from 9 metres to under 11 metres $800,000
from 11 metres to under 14 metres $1,000,000
above 14 metres $1,200,000
Other costs (fixed) $3,000,000
Basically i want in Cell X to get me the drilling cost to what cell Y says the rock thickness is. Then once its worked that out also at the $3,000,000 onto it?
I know its an If formula but do you have to keep putting an If in for every Variable?
Old Apr 27, 2005 | 02:13 PM
Dan B's Avatar
Dan B
Looks like you'll have to nest IF statements, but at least you'll be able to copy/paste the formula into every cell once it's written:
=IF(A1<=5,"400000",IF(A1<=9,"600000",IF(A1<=11,"80 0000",IF(A1<=14,"1000000",IF(A1>14,"1200000")))))
Pretty sure the above, converted to "normal English", means "If A1 is less than or equal to 5, then set value as 400000; else if A1 is than or equal to 9, set value to 600000, and so on...
Have that to work out the drilling cost, then use =SUM(B1+3000000) for the total cost.
The above assumes your rock thickness values are in the A-column and you're outputting drilling cost to the B-column; change those cell-addresses accordingly, paste the two formulae into the relevant columns!
It's been a while since I did any excel-formulae-programming, but I "think" that should work...
Old Apr 27, 2005 | 02:21 PM
RSKim's Avatar
RSKim
WOW
Old Apr 27, 2005 | 02:27 PM
Rhys's Avatar
Rhys
Awsome nice one Dan
Old Apr 27, 2005 | 02:29 PM
Dan B's Avatar
Dan B
You're welcome!
Old Apr 27, 2005 | 02:34 PM
Paul Eggleton's Avatar
Paul Eggleton
Check this badboy out
=(ALLOCATE!G302*VLOOKUP(ALLOCATE!H302,in!$BE$12:$B H$442,3))+(ALLOCATE!I302*VLOOKUP(ALLOCATE!J302,in! $BE$12:$BH$442,3))+(ALLOCATE!K302*VLOOKUP(ALLOCATE !L302,in!$BE$12:$BH$442,3))+(ALLOCATE!M302*VLOOKUP (ALLOCATE!N302,in!$BE$12:$BH$442,3))+(ALLOCATE!O30 2*VLOOKUP(ALLOCATE!P302,in!$BE$12:$BH$442,3))+(ALL OCATE!Q302*VLOOKUP(ALLOCATE!R302,in!$BE$12:$BH$442 ,3))
Tracing problems is, errrr, interesting
Old Apr 27, 2005 | 02:41 PM
Rhys's Avatar
Rhys
LOL these formulas suck! lol
Vlookup another great function
For this one assingment i have been told i have to use the Poisson fct nd the Norminv fct Which i have both never heard of till the other day! I have now used them but not sure if they are correct
Old Apr 27, 2005 | 02:44 PM
Paul Eggleton
Heard of Poissions ratio but wtf is Norminv? Normalised inverse something ???
Old Apr 27, 2005 | 02:47 PM
Rhys's Avatar
Rhys
Its to do with Normal distribution. So yeah your right Normal inverse
Didnt know either of those fcts was in excel till the other day
Old Apr 27, 2005 | 02:58 PM
foreigneRS's Avatar
foreigneRS
Testing the future
have you programmed your own functions using vba?
Old Apr 27, 2005 | 03:03 PM
Rhys's Avatar
Rhys
I havent no.
Now lets not get to techinal
Old Apr 27, 2005 | 03:20 PM
JamesH's Avatar
JamesH
Soooooooo glad when I finished my Excel coursework
Old Apr 27, 2005 | 03:53 PM
Rhys's Avatar
Rhys
Just doing this one now, but for some reason it aint working
=IF(C9=0,"0",IF(C9=1,"randbetween(800000,1000000)" ,IF(C9=2,"randbetween(800000,1000000)*2",IF(C9=3," randbetween(800000,1000000)*3",IF(C9=4,"Randbetwee n(800000,10000000*4")))))
jessie_rs
Jan 5, 2016 01:16 PM
stevecfrst1
Sep 30, 2015 05:18 AM
RIB1122
Sep 17, 2015 07:45 PM
RSmark84
Sep 13, 2015 01:29 PM
