welding ?
Old Apr 6, 2005 | 10:38 PM
luke89's Avatar
luke89
Team HOTHOT!
Default welding ?
thinking bout getting my self a cheap welder to teach my self to weld should be coming in to bout £400 as my dads moving away friday to live in holland so getting some money wat sort of welder should i look at getting ? had a quick look at these looked ok ?
http://www.machinemart.co.uk/product...5&r=2031&g=105
or
but i really dont no what i should be lookin for ? what sort of gas can be used ? the sort i use for my bbq ? and were can i get the gas ? it will only be used when i feel to use it or if i get a car that needs SMALL bits of welding.
thanks sorry for all the questions
Old Apr 6, 2005 | 10:46 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i use a small mig welder, clarke turbo 180 i think, uses gas, good little welder for car work, not to powerfull to blow holes through everything
Old Apr 6, 2005 | 10:48 PM
GrimmeRS2K's Avatar
GrimmeRS2K
oh yeah u can buy small bottles of argon or co2 mix for about 8 quid, or u can buy big bottles, they do run out quick though
luke89's Avatar
luke89
Team HOTHOT!
grimmeRST, what gas is it that they use ? is it hard to weld ?
Old Apr 6, 2005 | 10:49 PM
luke89's Avatar
luke89
Team HOTHOT!
oh thanks mate were do u get the gas?
Old Apr 6, 2005 | 10:52 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i get mine from my local motor factors called wilco, halfords may sell it, the big bottles i dont know never brought one.
Old Apr 6, 2005 | 11:04 PM
luke89's Avatar
luke89
Team HOTHOT!
thanks mate will look round . any one els ?
Old Apr 6, 2005 | 11:09 PM
Toe Knee's Avatar
Toe Knee
Yea the little ones you can get from most places, halfords prob do and motor factors like Cliffords/Camberly AutoFactors etc etc.
The big canisters are harder to get hold of cos you have to be registered i think to get them. You get the canister then top it up at a specialist gas supplier.
For general welding the smaller ones are fine mate and you'd have nowhere to fit a big tank anyway
Welding is pretty easy to be honest its learning to get the right power settings so you dont burn thru but get a good constant weld. best way to learn is go to a scrappers and get some old panels and practice on em!!
Old Apr 6, 2005 | 11:12 PM
user 769729789's Avatar
user 769729789
We use MIG welders at uni.
Very easy to use, can pick it up in a few days i rekon, even less that that!
If its a good finish your after though, you might be best getting good at rod welding.
Alot harder to pick up, but if you get it right, then the end results can be spot on
Personally i'd go for a MIG welder, easy, clean, and handy to work with.
Think the gas used is "argon", with a 25% C02 mix, most specialist toolshops will have some, the sizes vary. If you get serious though, different gases perform better on different metals.
Old Apr 6, 2005 | 11:13 PM
luke89's Avatar
luke89
Team HOTHOT!
thanks finding things to weld wont be a prob my mate drives a nova what would u say on the welder side ? the top one or the bottom one ?
thanks
Old Apr 6, 2005 | 11:18 PM
user 769729789
Doesnt seem to be much in it between the two welders you listed..
The 2nd one has a wider control on the power settings, (allows up to 170amps) but you'd neet to be doing some crazy stuff to need 170amps i rekon
If it was me buying.. id go for the 1st one, cheaper, and much the same spec, better for a beginner, unless you plan to do alot of welding? in that case, id go for summit a bit more industrial.
Old Apr 6, 2005 | 11:21 PM
AJ Escos's Avatar
AJ Escos
top welder would be more than capable of any general welding you would need to do, also i went round a couple of local bodyshops and got some damaged panels they would otherwise have binned to practice on
Old Apr 6, 2005 | 11:24 PM
luke89's Avatar
luke89
Team HOTHOT!
thanks for the advise lets just hope me old man gives me the money then ill call up and order one and go to halfords and see if they have the gas AJ Escos, good idear bout the body shop and the other day i went for a interveiw and as well as having a garge (mecains) he owns a body shop so could be in luck
Old Apr 6, 2005 | 11:27 PM
Cowboi's Avatar
Cowboi
i got a mig mate 130 turbo, more than good enough for car stuff. halfords sell them any they aint to expensive.
but if u can get into some where like maccess or any trade shop you can get them really cheap, and the gas is only about 4 quid a bottle aswell. (about half halfords)
a decnet welding mask will help as well, the ones you get with the welder is pretty cheap and hand held, it helps to have both hands useable.
Old Apr 6, 2005 | 11:35 PM
luke89's Avatar
luke89
Team HOTHOT!
http://www.machinemart.co.uk/product...8&r=2152&g=120
cheap mask ? will that do ?
Cowboi, thanks for that will ask around see if i can find a trade place
or would i be better with a gasless mig welder? http://www.machinemart.co.uk/product...0&r=2030&g=105
Old Apr 6, 2005 | 11:46 PM
Toe Knee's Avatar
Toe Knee
The ones u get are normally crappy ones mate. If you can afford it get one of the light sensitive ones, their see thru before u start welding so you can line up the welder before u start then go dark when you start welding, makes it so muc easier as you dont have to keep moving the mask back and forth when u stop inbetween welds
Old Apr 6, 2005 | 11:47 PM
Cowboi's Avatar
Cowboi
yeah that looks good. the thing i got with mine was pathetic.
You will need a business to get in most trade places, but if you know some 1 who knows some 1 you can sort it out.
I think i only paid 90 quid for my welder in the end, but i got staff discount on an already wicked price.
good luck with it, but be carefull not to distort panals and stuff, try and practice on thicker scrap, then thin scrap and then if your brave your car.
I was ok, i had a nova to learn on.
Old Apr 6, 2005 | 11:56 PM
luke89's Avatar
luke89
Team HOTHOT!
thanks for the advise every one so no one think i should get a gasless?
Old Apr 6, 2005 | 11:58 PM
Toe Knee's Avatar
Toe Knee
Get a gass'd one mate, from memory cos its been a while since ive done it you can still use gasless wire on a normal mig but not the other way round as it doesnt have the pipes for the gas built in
Old Apr 7, 2005 | 12:05 AM
Cowboi's Avatar
Cowboi
you can still weld when you run out of gas, but your "fusing" the metal together.
Now dont ask what that means, i was told it by a welder were i work.
He said it is a bit harder to do it when u run out of gas though.
Old Apr 7, 2005 | 12:12 AM
Toe Knee's Avatar
Toe Knee
doesnt the argon/co2 stop oxygen getting into the welds?!?!?!
As said you can still weld anyway jst not advised AFAIK
Old Apr 7, 2005 | 12:13 AM
luke89's Avatar
luke89
Team HOTHOT!
any one no any good sites to get gas from ? delivered?
thanks
Old Apr 7, 2005 | 12:26 AM
GARETH T's Avatar
GARETH T
buy a big second hand one mate,, from somewhere like ebay! you will get a much better welder,,, to get wleding right its all about ahjuxtabilty
plus a big welder will use the larger wire rolls,,which will save loads in the long run
Old Apr 7, 2005 | 06:45 AM
Paul Eggleton's Avatar
Paul Eggleton
Do not get a gasless one. THe gas in welding it to purge the welding area of oxygen. If oxygen gets around the welding area, you not only get ugly welds but the strength can be comprimised aswell. I've used 100% CO2 and a CO2/argon mix with good success.
And as Gareth said, it's worth spending a bit more to get a decent set.
I'm on the scrouge for a TIG set from work at the moment which is a bit different from MIG.
Old Apr 7, 2005 | 09:32 AM
luke89's Avatar
luke89
Team HOTHOT!
so i find out to day if i get more money , if i do depending on how much i will order on of the to welders and a face mask and then try and find places that do gas
Old Apr 7, 2005 | 09:59 AM
GARETH T's Avatar
GARETH T
http://cgi.ebay.co.uk/ws/eBayISAPI.d...504564540&rd=1
murex make well tidy welders
Old Apr 7, 2005 | 10:04 AM
AlexF's Avatar
AlexF
Luke if you want a hand learning to weld your only up the road from me...
I'd be happy to show you a few hints and tips
Alex
Old Apr 7, 2005 | 10:09 AM
luke89's Avatar
luke89
Team HOTHOT!
J871yhk, thanks my moneys not comin till monday dad just called so now im
Old Apr 7, 2005 | 10:27 AM
ian sibbert's Avatar
ian sibbert
Hi,
Dont buy the welder off ebay as per the link it's a 3 phase machine...I agreee with gareth though buy a quality welder.....
You can obtain (argosheild) the gas from any boc agent but you will have to pay rental on the bottle....this is the cheaper way...with a lot of welding you'll soon go through the small canisters...I have a large bottle which we only have filled every 6 months or so....15 kg rolls of wire do work out cheaper but we tend to just use 5 kg rolls from Partco....
Don't use the impregnated wire always use a sheilded weld you get less spatter and a cleaner weld...
Happy welding
Regards
Ian
Old Apr 7, 2005 | 10:30 AM
luke89's Avatar
luke89
Team HOTHOT!
sibster, thanks for the advice got a bit longer to look for the right welder now as i got till around monday till i get my money
Old Apr 7, 2005 | 10:33 AM
GARETH T's Avatar
GARETH T
sibster,
i didnt even notice it was a three phase bad boy
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
