Testing lambda sensor?
Old Nov 24, 2015 | 05:17 PM
Oranoco's Avatar
Oranoco
Default Testing lambda sensor?
I have a AEM AFR guage which has been giving odd readings for a while now. Today it just stopped. When I got the car back after the clutch and flywheel swap I found the sensor to be very loose in the thread and it'd been rattling about and the wiring had been left laying on the exhaust and the protective sleeve had totally melted. I'm hoping these 2 issues have wrecked the sensor but how can I test it?
Old Nov 24, 2015 | 07:28 PM
Rick's Avatar
Rick
only way is to plug it into another wideband controller. They are quite fragile so it probably is the sensor.
Old Nov 25, 2015 | 07:18 PM
stevieturbo's Avatar
stevieturbo
C**t
As above, no real easy way to test, and yup they arent that robust.
Old Nov 25, 2015 | 07:51 PM
Oranoco's Avatar
Oranoco
Will pop another in then and see how it does. Found the Bosch LSU 4.9 on ebay for about 45 quid.
Old Nov 26, 2015 | 04:05 PM
Rick's Avatar
Rick
make sure your controller supports/is setup for LSU4.9, many are still 4.2.
Rick
Old Nov 26, 2015 | 05:17 PM
Oranoco's Avatar
Oranoco
It came with a 4.9 in the kit originally so should be good.
MattSPL
Nov 11, 2015 05:10 PM
Rsturbo519
Nov 8, 2015 11:47 PM
mrmann
Nov 4, 2015 03:22 PM
Churtz
Nov 1, 2015 06:18 PM
Tank Mike
Oct 28, 2015 07:55 PM
