Compression test results
Old Feb 13, 2015 | 07:45 AM
Fordmad!'s Avatar
Fordmad!
Default Compression test results
Did a comp test on my rs2k last night to see if I can find out why its using oil.
They were 150 165 165 150
Is that okay? No major differences.
Also noticed the exhaust is very sooty on the tail pipe.
Old Feb 14, 2015 | 11:47 AM
Guinnless's Avatar
Guinnless
Did you check with all the plugs removed and throttle wide-open?
Valve stem seals and guides are a common reason on any engine for
oil consumption.
Old Feb 14, 2015 | 03:59 PM
Fordmad!'s Avatar
Fordmad!
No left plugs in and did one at a time. Was told to do it that way :/
I've noticed a very small leak but nothing too bad to use that much oil.
There's a lot of white smoke from cold on start up gets better when warm but still does a bit when warm.
Old Feb 14, 2015 | 05:25 PM
Hos much oil is it using matey. I would say the compression test is ok.
Old Feb 15, 2015 | 10:28 AM
markk's Avatar
markk
How would a compression test help diagnose oil consumption?
Old Feb 15, 2015 | 10:50 AM
Fordmad!'s Avatar
Fordmad!
Its used around 3 litres from June. Not sure how many miles that is. Id say max 3k but probably less
Old Feb 15, 2015 | 07:16 PM
studabear's Avatar
studabear
Cylinder leak down test is what ya want really.
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
