Help!!!
Old Jun 22, 2014 | 07:31 PM
Anne27's Avatar
Anne27
Cossie
Default Help!!!
How do I know if my head gasket is going? Advice pls..
Old Jun 22, 2014 | 07:55 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
there are many signs sometimes 1 or a few,
why do you suspect this, more opinions will follow , I`m sure
STeve's Avatar
Super Moderator
oil in your water or steam out of exhaust or water in your oil with mayo round filler cap are a few of the obvious ones
Old Jun 22, 2014 | 10:35 PM
Anne27's Avatar
Anne27
Cossie
Full loss of coolant from expansion tank (unclear what caused the loss) - believed to occur over a couple of days.
Car drives normally at all times.
Temperature gauge reads normal. After a short spell of driving with boost (high rev range) the temperature gauge drops quickly - below the scale. Coolant appears to be boiling in the expansion tank.
Have checked for air in system. Doesn't appear to be any air (have checked bleed point and run for a while with expansion tank cap removed). Thanks for advice
Old Jun 22, 2014 | 10:59 PM
mk2grp1's Avatar
mk2grp1
some garages can pressurise the system and test for leaks,
some can analyse the water for noxious gasses, I;e inpending gasket failure.
others just hit and hope, water could vapourise as steam, if boiling up yes,
is cooling fan working,
could be leaky rad leaky heater matrix, pinhole in a water pipe thermostat housing rubber ring letting go, my guess its a zetec that's why I say rubber ring, loose hose clip,, what car would help , water pump gasket or failing pump seal ,
cream under oil cap as per 1-PD would indicate water in oil or dipstick tube or in breather pipes
Old Jun 23, 2014 | 11:13 AM
Sometimes you can get misfires too.
Old Jun 23, 2014 | 12:16 PM
Anne27's Avatar
Anne27
Cossie
Sapphire cosworth. Ok thanks will get them checked!
Old Jun 23, 2014 | 03:22 PM
andy.v's Avatar
andy.v
sniff test
Old Jun 23, 2014 | 03:31 PM
Stu @ M Developments's Avatar
PassionFords Creator
Easy...
Step 1) Walk to the rear of the vehicle
Step 2) Look at the boot-lid just above the exhaust pipe
If it says "Cosworth" anywhere... the head gaskets gone.
Old Jun 23, 2014 | 03:35 PM
On a more serious note - it sounds like you have indeed got a potential head gasket failure, but what your describing can be caused by other things too such as a stuck thermostat or sheered off water pump rotor. Both will cause localised boiling of the water which then creates pressure, air locks and water loss.
Does the system run the correct head pressure?
Once its up to temperature does loosening the cap release pressure or not? (It should and must)
Does water flow correctly around the system, has it been checked?
Old Jun 23, 2014 | 08:11 PM
sridgett's Avatar
sridgett
The only way is dagenham
Hi there Anne27 not seen you on here befor.
