Need a Doughnut.....
I need a new propshaft doughnut, As you can see from the pics it's split.
Ive been to ford and they reckon you have to buy the hole propshaft?
You must be able to get these some how does anyone know?
If its the bit which bolts between the box and the prop, and its the same as an ECos 4WD item... I have one .... Dunno what its worth??? a Score delivered?? (provided it aint gonna cost too much for delivery, cant recall what they weigh).. or you can pick it up from East London???
I will get some numbers off it to compare and some images or summat tommorrow. any good to ya??
Escort ones and Sapph ones are different, the output shaft on the Escos box is different to Sapph.. However, someone having fitted an Escos box into your Sapph can't be ruled out, so worth checking the numbers I guess!
When I made enquiries at Ford I was told the same
Just dont order one off Pete at Ashfield like I did
The term mint obviously has a different meaning to him than to me. Charged me about Ł50 for it if I remember rightly and when I got it it was cracked to fook - no better than the one that I wanted to replace!
Would be good to know whether Powerflex/deflex have started making these for sure?
saw one today in fast ford, deflex have started making them, Ł40 give em a call on
01745 360070 or go to www.deflex.co.uk
deflex dont make these donoghts
theres ares for granadas and 2wd sierras not 4wd
these are very hard to het hold of ford dont do the propshaft anymore so that rules that out as i went to buy the prop just for the donught
the only car that has the same donught is either a 2.9 or 2.0 xr4x4
escort cosworth are a lot thinner due to having a longer input shaft so this wont work
ive already had this problem and it took me months to test and try things
in the end i found a xr4x4 breakers and he supplied me with a mint one
ok it had one slight split oubout 1 cm long but hadnt gone through
heres his number if anyone is interested
01702 433233
just ask for the donught off a 2.9 or 2.0 xr4x4
hope this helps
p.s do not fit a deflex one onto a 4wd as it doesnt have the bearing in the middle to centre the prop shaft up
i did this and got to about 110mph and it shock the car badly drove through it and it snapped the transfer box in half just a warning to u peeps
01702 433233
hope this helps
On a serious note.....
PM or Email "Neilm" he gets probs refurbed/modded he may be able to shed some light on subject....
neil@105speed.com
neil@105speed.com
If you PM me the details of Year, etc .. I will look at my Ford systems tomorrow for a service item
Maybe even find parts overseas (that dealers cant see)
Cheers...
Cheers...
