07 plate transit key
So today i ive had a headache with one of the vans , put the key in and you have to hold it on the third click to keep the van running or it just cuts out. S oi take it i need a new key (its really worn) and ignition barrell. How much am i looking at if i take it to fords tomorrow and how long do they need the van for??
Dave I HATE new fords.............. |
Barrell is £35, the read your key and make it there and than to suit. Then fit it yourself.
and what they charge you for the key?
no dealers around here make locks to keys anymore
You can get a new blade for about £3.
I had to do the same for my Focus as it was well past it! |
Originally Posted by Bailes1992
(Post 5838724)
Originally Posted by sapph1
(Post 5838764)
You're still gonna have to get the key coded though so there's an hours labour
My Focus was my Mums for 8 years whos a district nurse. The key and ignition barrel were destroyed. Got a new blade for my key and a new ignition barrell for less than £40! |
Depends if its a remote key or not though, if it is then like you say, just change the blade, if its a normal key it will need to be coded. Unless you can dig the chip out of the key and swap it lol
(Post 5838764)
If it's the blue key, it costs £135 inc vat for a complete coded and cut remote key. Glad we don't have to pay, leased vans, and they want the van all day. And you can't change the blade on a genuine Ford key, the fob is glued together, battery is not replaceable it's recharged whilst in the igniton. That's without the cost of the barrel and fitting. . |
Its the blue key . ive even tried using the spare (just a plane black ford key) and the van still cuts out while on the move if the key even moves slightly.So im looking at £30 barrell £135 key and a days labour??
Are you sure its the barrel and not the ignition switch.
Yes mate its the barrell and key, just called fords and they want £279.85 and need the van for a day even though they said it takes 1 hour :wall:
Originally Posted by Harris.
(Post 5839031)
Last time I tried to use a Ford Rapid fit centre, not Kwikfit, they still wanted to book it in. |
If it's the blue key you can remove the black section at the bottom (the Blade) and replace it for around £3. You can take them apart as I did on a hire van a few weeks ago :lol:
© 2024 MH Sub I, LLC dba Internet Brands
