Think i've put diesel in a my Focus petrol
#41
I've removed the rear seat, there is no access hole for the tank, just a tiny grommet where the wiring goes through. Saw a video on you tube and people cut the floor away to get at it. I can't do that as have given all my power tools away, plus it seems more hassle than it's worth.
I bought a syphon pipe and tried to put it in, it won't go in as there is an anti syphon protection.
Today, i've put another half a tank of unleaded in it, there is now 3/4's of a tank of unleaded and just a couple of litres of diesel. It wouldn't start, been trying all day. Got some Easy Start and sprayed it in, got the car started with that, then it caught and ran fine for about 10 minutes although really lumpy at idle. It burnt out all the diesel in the cylinders as there was plumes of smoke coming out the exhaust which then cleared up. I turned off and tried to restart it once warm, it wouldn't restart at 1st but did the 2nd turn. Decided to drive it, pulled a bit rough but not too bad.
Didn't get very far, it cut out when the rev's dipped as I was braking. It wouldn't restart for love nor money, even with the Easy Start.
It's doing my head in, can't understand how it can run for a bit then not anymore.
#44
Missfire detection is carried out two ways, and only two ways at present.
Either the coils are monitored and a missfire is detected that way ( current required to charge will change, or it can detect not firing at all due to no discharge )
or by monitoring crankshaft acceleration just after a spark has occurred.
#47
Sounds like you've put more diesel in than you're letting on.
And it's a total waste of time trying to dilute it with half measures. If you are totally against draining the tank, then you must replenish the tank with as much petrol as possible so it dilutes the diesel more.
And you can empty the tank using the cars fuel pump. Disconnect a fuel line somewhere, route this to a suitable container and power up the pump ( either manually at the plug/wiring near the pump, or by energising or bypassing the pump relay manually )
And for the next few weeks, you must keep an eye on the oil, and it will need changed.
The diesel will not burn off the same way, and it will end up mixed in with the oil in the sump thinning it down.
#48
It wasn't a full Jerry can so i'm guessing it was 3 to 4 litres.
I don't care about the engine oil or anything like that. Moving to Brazil in a week and the car is being weighed in.
I'm a bit weary about putting more petrol in to dilute it, as it seems to be doing fuck all, it's got about £40 in it at the moment and is still acting up.
Suppose i'll have to just bridge the pump relay and tip it all out. Wish i'd done that £40 ago...
#50
all sorted, I bridged the pump relay to get rid of all the old stuff. Changed the fuel filter and put in some more unleaded. There was still a fair bit of the old stuff left in the tank, but it's running ok but idles rough.
I'm happy, thanks for all the advice guys
#51
Watch the level very closely, as diesel will find it's way into the sump both raising levels and thinning it out quite badly.
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
