new cosworth jenvey turbo plenum
at last jenvey have made the plenum fit the yb , it looks a serious piece of kit aswell:clap:
http://www.jenvey.co.uk/images/stori...g%20plenum.pdf cheers paul |
Very nice ! I want one !
Looks nice, wonder who will be first to use it on an ST/RS 5 pot....
nice it looks like hart plenum ..
Nice as it looks, with the main bit of the plenum on top like that with a throttle body on the end and an iscv sticking up i dont think you'd be able to shut the bonnet!
From memory you can swap that bit over.
Good looking plenums though |
Originally Posted by pacificzetecturbo
(Post 5737213)
heres my zetec one as you can see the front cover is bolted and so is the difuser http://i457.photobucket.com/albums/q...Photo-0178.jpg http://i457.photobucket.com/albums/q...Photo-0175.jpg http://i457.photobucket.com/albums/q...aulpics570.jpg mounted the other way http://i457.photobucket.com/albums/q...aulpics558.jpg cheers paul:top: |
Looks good.
I dont understand why it says " equal pressure across the inlet ports I was taught that the pressure in a container is the same no matter where it is measured from, A plenum is just a funny shape of container so I cant understand why there would be a pressure difference between inlet runners ? |
Its because of the way the air enters the plenum.
It is distributed more evenly across the 4 outlets. Dont for get this inst a "stable" container. When the valves open it changes the volume of the "container" and the ports are in different places inside so will pull the air in different directions... |
its the design of the diffuser that give equal pressures across all inlet ports
heres a picture looking down the diffuser and we can see the taper built into the diffuser housing , http://i457.photobucket.com/albums/q...aulpics575.jpg it would be nice to know what extra power it gives on a high powered yb as the one they tried on the evo jumped up 70bhp over the standard inlet and the engine was a high powered evo before anyone says it wasnt. cheers paul |
Originally Posted by stu21t
(Post 5737424)
Originally Posted by zetaboostboy522bhp
(Post 5737483)
Originally Posted by Fiesta_Jed
(Post 5737511)
I understand how this could affecct the volume of air each cylinder consumes but I dont see how the pressure could be affected ????
http://i765.photobucket.com/albums/x...y/inletcfd.jpg http://i765.photobucket.com/albums/x.../inletcfd2.jpg |
have a read of this as its a very complex subjuct and this helps alittle , iam sure jenvey know all this and have design it to be as good as it can be
http://amsperformance.com/pdfs/intakemani.pdf cheers paul |
http://i765.photobucket.com/albums/x...y/project1.jpg
variation of jenvey manifold and others for a very high hp evo engine. |
Originally Posted by dug112y
(Post 5737534)
variation of jenvey manifold and others for a very high hp evo engine. cheers paul:top: |
the twin one is machined from billet with the jenvey runners bolted on.....
i only wish it was my engine....its an extreme tuner no expense spared 2000hp evo engine build. the money spent on it is unbelievable. i do wonder how it would work on say cossie engines but i think the exhaust port flow on a cossie(120 cfm) is limited compared to an evo(176 cfm) same flowbench/pressure etc. |
The build for that evo is impressive. Certinaly is no exspense spared as you say when you see the sort of materials they are using to make things
link to the build thread for said evo?
Any ideas how much for one of these bad boys?
© 2024 MH Sub I, LLC dba Internet Brands
