Dead mapsensor maybe
Old Apr 20, 2011 | 06:57 PM
Hansenturbo's Avatar
Hansenturbo
Default Dead mapsensor maybe
How does your cossie act when the mapsensor dies?
Old Apr 20, 2011 | 07:21 PM
I'm sure most tend to go super rich, when the map breaks.
Old Apr 20, 2011 | 07:25 PM
scoooby slayer's Avatar
scoooby slayer
thats what mine did when map failed, would just about run wth throttle flat out pumping out black smoke
Old Apr 20, 2011 | 07:35 PM
v man's Avatar
v man
Zee Germans are coming
yep turn massively ritch and wont run
will kill the plugs and fill your exhaust up with fuel
and when you fit a new map sensor it will smoke so bad you will gwt pulled over by police and have to explain whats going on
thats what happened to me anyway
Old Apr 20, 2011 | 08:29 PM
Hansenturbo
Okay my car just die when it comes on boost then it just kill
the engine :-(
Old Apr 20, 2011 | 09:39 PM
martysmartie's Avatar
martysmartie
As said it they will run massively rich, it's common for them not to start, the flash code system will tell you if so.
When it cuts out does it shudder or just stop?
Martin
Old Apr 21, 2011 | 01:44 PM
Hansenturbo
When i hit the revs it dies i can adjust co on the ecu and get it to rev to 5000rpm then it just cuts and dies :-(
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
Flatlinedan
Sep 18, 2015 12:41 PM
23
Sep 12, 2015 12:56 PM
