co2 pot needed
Old Jan 10, 2011 | 07:38 PM
brianL84's Avatar
brianL84
Default co2 pot needed
i have an h reg xr3i efi and have found that the co2 pot is dun and cant find a new one anywhare if anybody could help me find one that would be great .i also herd that if i use a throttle position sensor from the same car it works in the same way but not to sure about this maybee someone with a bit more no how than me could tell me thanks
Old Jan 11, 2011 | 11:52 AM
You need to know the resistance, then you can simply pop into maplins etc and buy one, even if you can't get the exact one the nearest resistance would usually be ok.
This can always be mounted remotely(outside the ecu) if needed.
Old Jan 13, 2011 | 04:48 PM
brianL84's Avatar
brianL84
dus anybody have a rough idea of the resistance ?
Old Jan 13, 2011 | 04:53 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Is it a separate part? If so is the Sierra DOHC one the same? I have a couple of dead ones here.
Old Jan 13, 2011 | 08:12 PM
brianL84's Avatar
brianL84
its the little black box with a screw on the top of it with a 3 prong plug going to it that sits on the passenger side inner wing .i put the meter on it and its not adjusting my mixture so trying to find one thats working or if anyone can tell me the resistance and i will get a replacement potentiometer
Old Jan 13, 2011 | 09:04 PM
frsjon's Avatar
frsjon
have a look on ebay under fiesta rs turbo...seen a few on there lately
Old Jan 14, 2011 | 08:02 AM
Martin-Hadland
Sounds the same as a Sierra but sadly the Sierra one has only two terminals.
james kiely
Aug 28, 2015 08:58 PM
SteveyDee
Aug 24, 2015 05:43 AM
Dahl88
Aug 22, 2015 08:16 PM
RsS2daz
Aug 14, 2015 05:26 AM
col93saphcos
Aug 7, 2015 03:21 PM
