What size of scrambler?
What size of scrambler would you recommend, im not used with motorbikes, i was on an 80cc before and thought it was very lifty. I looked at a 250 kx today but it was massive, im 6ft 2 but i had to lie it down to the side to throw my leg over.
Would a 125 be better, its not for anything serious just spinning about the farm. Is all 125s the same size as in is their ones for children. I dont want to go looking at one and find out its for a child? |
bikes come in all sizes with same engines. I think its the wheel size that dictates the frame size. A kx250 would be a bit much for a newby.125 will be fine. Or they do 4 strokes that are more civilised
if its for pottering about get a 250 4 stroke or 2 stroke maybe a 125 2 stroke but nothing mental
i looked at a crm250 today that would be perfect for that sort of thing as its not so highly strung its needs loads of mainanance cheap too at 650! with road docs too a propper crosser will need love and care, i looked at a few this weekend and be very careful you have to know your way around one, traveling to look at summet thats fucked is very annoying especially when on the way home you hear theres a newer and totally pristine yz250 for not much more inc new set of plastics £2k of trick bits and its never been in top gear- buying from rich kids the the way forward if its for fields and the odd jump get a road styled crosser, excellent fun, hardy and still plenty of punch ive been looking on gumtree, least you are local then check noises, bike engines tell you when they are fucked and you can tell alot from the taps dont beleve the advert, if they say they service it every day look at the oil, if its black its been left un serviced chain and sprokets and tyres are service items but good uns will save you a couple of ton get it in the air and wiggle wheels front to back (but stationary) to see if theres movement in wheel bearings and headstock bearings, whiel its in teh air go thru the gears while it runs, will show any slack or bad noises without leaning down while you ride check those numbers, crossers get stolen every day and then sold a millions times over too, check a crosser forum, its everywhere (looked on the ktm forum and a guy had his bikes lifted when the removed tiles from the garage dropped down and used his tools to unlock bikes then his trailer to nick em) dont beleve ebay prices, local bikes are much cheaper dont buy chinese if you want it to be trouble free today i asked 2 people i was doin jobs for if they knew any crossers (chit chat whil working) both had recently sold good bikes for cheap money, ask everyone yoe meet and you may fall on a good un (im buying a minter yz250 2006 thru a mate and it it truley immaculate) |
also whats your budget and about the years you fancy?
older stuff is always smaller |
get a KX 250 and rip the farm up mate.
im 5'1" and used to ride a yz250 so dont b a girl, get the 250.
go for a ktm 125 or 200 they are the same size and are a good quality bike,and on the + side plenty of cheap bikes around at xmas.
all 125, 250, 450 etc. crossers are basically the same height, at 6ft 2" you
should fly on 1 mate. if a crosser is too powerfull for you then you'd be better off looking at road bikes like the kawasaki KMX 125 or 200, yamaha DT 125, honda XR 125 or 250. |
So are you telling me a 125 will be the same size of bike as a 250. The man that owned the 250 said the kx was a bigger bike and his mate had a yamaha and it was smaller, his mate races them but he couldnt sit on the kx to start her but could sit on the yamaha.
I was looking gumtree and i saw a 125 kx and it said it had the bigger wheels. For starting off and putting my feet down more than normal it was definately to big. |
i've had motocross bikes since i was 5 so yes that is what i'm saying, if 1 is sitting lower then the suspension has either been adjusted or its fucked.
heres the specs of a 2011 KTM 125SX, 2011 KTM 250SX and 2011 KTM 450SX for you to compare the wheel base,ground clearence and seat height etc. 2011 KTM 125SX: Engine type Single cylinder, 2-stroke Displacement 124.8 cc Bore x stroke 54 x 54.5 mm (2.13 x 2.15") Starter Kickstarter Transmission 6 gears Carburetor Keihin PWK 38S AG Control Exhaust control Lubrication Mixture oil lubrication 1:40 Transmission oil Motorex, SAE 15W50 Primary drive 23:73 Final drive 13:50 Cooling Liquid cooling Clutch Wet multi-disc clutch, operated hydraulically Ignition Kokusan Frame Central double-cradle-type 25CrMo4 Subframe Aluminium Handlebar Renthal, Aluminium Ø 28/22 mm (1.10/0.87") Front suspension WP USD Ø 48 mm (1.89") Rear suspension WP PDS shock absorber Suspension travel front/rear 300/336 mm Brakes, front/rear Disc brakes 260/220 mm (10.24/8.66") Rims, front/rear 1.60 x 21"; 2.15 x 19" Excel Tires, front/rear 80/100-21"; 100/90-19" Chain 5/8 x 1/4" Main silencer Aluminium Steering head angle 63.5° Wheel base 1480±10 mm Ground clearance (unloaded) 385 mm Seat height 992 mm Tank capacity approx. 7,5 liters Weight (no fuel) approx. 88.8 kg 2011 KTM 250SX: Engine type Single cylinder, 2-stroke Displacement 249 cc Bore x stroke 66.4 x 72 mm (2.61 x 2.83") Starter Kickstarter Transmission 5 gears Carburetor Keihin PWK 36S AG Control TVC power valve Lubrication Mixture oil lubrication 1:60 Transmission oil Motorex, SAE 15W50 Primary drive 26:72 Final drive 13:48 Cooling Liquid cooling Clutch Wet multi-disc clutch, operated hydraulically Ignition Kokusan Frame Central double-cradle-type 25CrMo4 Subframe Aluminium Handlebar Renthal, Aluminium Ø 28/22 mm (1.10/0.87") Front suspension WP USD Ø 48 mm (1.89") Rear suspension WP PDS shock absorber Suspension travel front/rear 300/336 mm Brakes, front/rear Disc brakes 260/220 mm (10.24/8.66") Rims, front/rear 1.60 x 21"; 2.15 x 19" Excel Tires, front/rear 80/100-21"; 110/90-19" Chain 5/8 x 1/4" Main silencer Aluminium Steering head angle 63.5° Wheel base 1495±10 mm Ground clearance (unloaded) 385 mm (15.16") Seat height 992 mm Tank capacity approx. 7,5 liters Weight (no fuel) approx. 93,8 kg 2011 KTM 450SX: Engine type Single cylinder, 4-stroke Displacement 449.3 cc Bore x stroke 97 x 60,8 mm (3.82 x 2.39") Compression ratio 12.5:1 Starter Electric starter/12V 3 Ah Transmission 5 gears Carburetor Keihin FCR MX 41 Control 4 V/DOHC with finger followers Lubrication Pressure lubrication with 3 oil pumps Engine lubrication Motorex, SAE 10W50 Primary drive 29:74 Final drive 14:52 Cooling Liquid cooling Clutch Wet multi-disc clutch, operated hydraulically Ignition Kokusan Frame Central double-cradle-type 25CrMo4 Subframe Aluminium Handlebar Renthal, Aluminium Ø 28/22 mm Front suspension WP-USD Ø 48 mm (1.89") Rear suspension WP-Monoshock with linkage Suspension travel front/rear 300/330 mm Brakes, front/rear Disc brakes 260/220 mm (10.24/8.66") Rims, front/rear 1.6 x 21"; 2.15 x 19" Excel Tires, front/rear 80/100-21"; 110/90-19" Chain 5/8 x 1/4" Main silencer Aluminium Steering head angle 63,5° Wheel base 1495±10 mm Ground clearance (unloaded) 371 mm Seat height 992 mm Tank capacity approx. 7.5 liters Weight (no fuel) approx. 106.9 kg |
i love crossers; havent had one since i was a boy (15), i was on a RM125 then; so at 6ft 2" you shouldnt have any bother?
the 125 is good to learn on but once you've go used to it; you;ll soon be bored. i'd get a 250 if i were you |
crosser's fucking scare me:cry::cry: only been on 1 true crosser and it wasnt a nice experience.
buy a quad
jason |
Get a nice cr250 and ring its neck.
I dont know what to think anymore. It wasnt the power that scared me it was the sheer size and weight. In an open field where your not stopping all the time its probably easier. For any1 under 6 foot to take it down a narrow lane and try and turn it around, i cant see how they could do it without jumping off and wheeling it around.
Just going to be a case of getting used to it mate, all big lumps but when you are familar with it it will be second nature.
Pick up something you can bash about that isn't mint until your used to it then move up. |
i would go for a 125 mate, i had never ridden a bike before i got 1 a few year ago, im just under 6ft and it wasnt really a problem, just go steady with the clutch!
i got a cr125 1987 now that im restoring when funds/time allows and when sat on it, i can put both feet on the floor on my tiptoes so not too bad |
Originally Posted by cossie legend
(Post 5164445)
full lock and dump thd clutch, the bike will get you round in 1 you shoudl never have the wheels traveling at the same speed as the dirt on a crosser :cry: |
Im a road bike man and crossers can scare me :cry:
I know someone who RACES supermoto's and moto x. He races a 125 crosser and only gets reeled in on the straights. Only now after a few years racing is going to move to 250 to be more competitive. That tells me all i need to know about whether anyone really needs a 250! |
just get a four stroke 450 suzuki, very easy to ride...
two stroke`s are a lot of work |
cr 500 ftw! the only bike ive owned that genuinley scared me, make sure you dont break your leg slipping off the kickstart tho they are lethal!
Ive had a yz250 4 stroke which was a nice bike to ride,not as aggressive as my more recent kx250 2 stroke which was a bit of an animal lol im 6ft and was 16 stone at the time so it was fine for me!
Originally Posted by botters
(Post 5164566)
Originally Posted by mrjenrst
(Post 5164580)
that was the only proper crosser i've been on, i shit myself fucking cunting insane them things put me off big time! I started gently put it in second and the bastard of a thing was spinning the back while the front was coming up. Knocked it into 3rd same fucking thing wtf! It was a monster, only had a few goes tbh and the same thing every fucking time
it looked like someone had gone across the field with a plow! suffice to say on a drier day it wheelied like fook! |
(Post 5164602)
when i first got mine years ago (i was about 15) i took it out in the pissing rain on a field near home, i was gutted that it wouldnt wheelie in any gear no matter how hard i tried until my mate pointed out it wasnt doing wheelys because i was just digging massive trenches behind me with the back wheel lol!
(Post 5164608)
There insane mate, the day we went out was dry and it was spinning the rear like it was a slick in the wet. It sounded the nut's full dep system. tbh i'd love to motard one and make it road legal lol
(Post 5164616)
would be nice for traffic light grandprix bet there isnt much that could touch it in the dry with a bit of weight over the bars lol
i got myself a rm125 in the summer, great fun and been spot on, all proper 125 crossers though are pretty big bikes i believe and fairly lairy too :ban-split:
KTM 500 watercooled lol :cry: my mate had one, tried to kill us all
buy an enduro bike - best of both worlds trail and scrambler
i've had 2 kdx 200's and they were cracking bikes reliable , lightweight etc for me 125 scramblers scream their heads off and a 250 may be just to big for you the now |
Originally Posted by phil robson
(Post 5164523)
i got a cr125 1987 now that im restoring when funds/time allows and when sat on it, i can put both feet on the floor on my tiptoes so not too bad just noticed your bits about the cr, im gonna restore my 88cr125 soon so if you find a stash of parts i will need a few |
Fuck getting a proper 250 crosser for a first bike... Stick with a 125 imo
My good mates race tuned yz 80 would give you a shock!! |
© 2024 MH Sub I, LLC dba Internet Brands
