clyde
Old Oct 14, 2010 | 12:28 PM
clyde's Avatar
clyde
Unhappy clyde
I have a 1985 For Xr3i.The Car start and i can drive it, but it continiously kills the nr 4 spark plug and when you smell the oil in the sump, you can smell petrol.The oil was changed x3 with petrol evident.Can this be cause by a leaking inlet valve?
Old Oct 14, 2010 | 12:57 PM
phil_focus's Avatar
phil_focus
is your oil level going up over a period of time?? i'd say you're piston rings are fucked and petrol is getting down into the sump.
Old Oct 14, 2010 | 04:23 PM
cossie604's Avatar
cossie604
Default cossie604
Hi Clyde and welcome to the site
As said, sounds like you've got some proper piston ring issues going on. Done a compression test or cylinder leak test?
Old Oct 15, 2010 | 08:59 AM
clyde's Avatar
clyde
Hey, thank you guys.I will do a compression test on the cylinders and give you guys feedback regarding my findings.
clyde 1800
Oct 7, 2012 10:30 PM
clyde 1800
Mar 11, 2011 05:44 PM
clyde 1800
15
Feb 19, 2011 09:05 PM
rabmc
Jan 17, 2009 05:11 PM
