Lambda sensors: How do you go about fitting them?
Old Jan 25, 2005 | 06:51 PM
boXXer's Avatar
boXXer
GASH!
Default Lambda sensors: How do you go about fitting them?
Hiya, as my exhaust is off at the moment, im thinking about fitting a lambda sensor into the exhaust somewhere. How easy is it? and where do you get all the parts from? i.e, the boss to hold it, actual sensor, etc.
Mike.
Old Jan 25, 2005 | 07:50 PM
boXXer's Avatar
boXXer
GASH!
Old Jan 25, 2005 | 07:55 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its simple enough pal, but depends what you want to fit and why?
Il help ya once weve ascertained this info
Old Jan 25, 2005 | 07:57 PM
boXXer's Avatar
boXXer
GASH!
well, all i wanna do is to be able to monitor the car when im giving it some, just to make sure it dont run lean and blow up.
cheers
Mike.
Old Jan 25, 2005 | 08:04 PM
Well i have just the damn topic for you then
https://passionford.com/forum/viewtopic.php?t=97837
Old Jan 25, 2005 | 08:07 PM
boXXer's Avatar
boXXer
GASH!
errrrm oooooooooooooooooook.
Old Jan 26, 2005 | 07:41 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you can get weld on bosses for the lambda sensor but i always seem to have grief with them. i first drill a 20mm hole for the lambda sensor (M18 type wb NTK), then place the boss (with bung screwed in) over the hole and tack it in place. then weld around the rest of the hole slowly doing opposite sides to try to not put too much heat and distortion into it.
but more often than not, the boss does get distorted by the heat of welding it, and the bung won't come out
any tips?
ekjim
Aug 27, 2015 05:20 PM
Dahl88
Aug 22, 2015 08:16 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
