How much??
Old Jan 23, 2005 | 08:51 PM
righthooker's Avatar
righthooker
Default How much??
Would you normaly expect to get a cossie set up? Been around two and a half years since she last got a tune up and has started to hunt on idle.Would also like to get it done for piece of mind ,Fueling and so on,allthough the lambda says all in the green . cheers in advance
Old Jan 23, 2005 | 08:53 PM
Stu.H's Avatar
Stu.H
I asked karl this exact question, and was told if set up correctly 1st time it shouldnt need setting up again, unless there is and addition/change to engine bits ie filter/zorst/cooler etc
Old Jan 23, 2005 | 08:58 PM
Ginge !'s Avatar
Ginge !
just finding my feet
recomended to get it checked once a year though
its bout 100 quid to set up
Old Jan 23, 2005 | 09:02 PM
righthooker
i have just put a 500 cooler on so i dont know if that makes too much diference ,allthough it has only started hunting after this change
Old Jan 23, 2005 | 09:07 PM
Ginge !'s Avatar
Ginge !
eayh that counts as a change as the presure will drop
hunting is usually the iscv or the CTS can cause it too are ya using more fuel
