wheel offset
Old Aug 20, 2010 | 05:33 PM
gus's Avatar
gus
Default wheel offset
can you measure a wheel offset with the tyres still on?
i got a set of wheels fitted with tyres and wanna know the et as they not what i thought
Old Aug 20, 2010 | 06:40 PM
STeve's Avatar
Super Moderator
surely its stamped on the rim somewhere what the et is,fwd or rwd or foreign jobbys etc etc
Old Aug 20, 2010 | 06:43 PM
Bullett's Avatar
Bullett
it can be done but you need to get a flat bar across the back of the rim and make it level to the rim edge.then measure the distance down to the hub. after that really you need a conversion chart.
if you do these and tell me the diameter and wheel width i can ring someone on monday for you to find out
Old Aug 20, 2010 | 06:44 PM
gus's Avatar
gus
they aint stamped otherwise that would save me messing about with a tape measure and flat edge
Old Aug 20, 2010 | 06:46 PM
gus's Avatar
gus
dont you take the measure from where the tyre bead sits? inner rim
instead of outer lip
i know you measure the backspace and take off from wheel centre, just unsure where the wheel is measured from
Old Aug 20, 2010 | 10:14 PM
Dlatch!'s Avatar
Dlatch!
first measure rim width
then back space the difference between the two is your et
Old Aug 21, 2010 | 04:20 AM
gus's Avatar
gus
is rim width measured from the outer lip tho?
or
from where the tyre bead would sit?
Old Aug 21, 2010 | 07:07 AM
foxy06's Avatar
foxy06
I would imagine the outer lips, usually always full or half inches 8", 8.5" 9" etc so wotever the measure is nearest.
Old Aug 21, 2010 | 07:58 AM
Bullett's Avatar
Bullett
the way i described is the way i had to do it for a customer of mine to find out what offset his racelines were on his jwrc kitted fiesta.mu suppliers converted it for me from the info i gave them
Old Aug 21, 2010 | 08:16 AM
gus's Avatar
gus
i dont know the wheel width tho
this is what im getting at
i know how to measure the offset (sort of) but need to know where / how to measure the wheel width first, with the tyre on
Old Aug 21, 2010 | 08:32 AM
rubinsbin's Avatar
rubinsbin
FFSake------DEAR 'O' DEAR-------JUST IMAGINE NO TYRE ON THE WHEEL!!!,the tyre got f-all to do with it-----
STRAIGHT EDGE ACROSS THE RIM AND MEASURE DOWN TO THE FLAT AREA BINGO!!.
Old Aug 21, 2010 | 08:38 AM
gus's Avatar
gus
who you shouting at!!!!!!!!!!!!!!!!!!!!!!!!
measuring from flat edge to hub will only give me the back space
i need to know if the tyre is measured from inner or outer rim lip so i can work out the wheel centre
Old Aug 21, 2010 | 08:55 AM
S1's Avatar
S1
It doesnt actually matter where the wheel width is taken from. Measure the complete width of the wheel. I usually find the actuall overall width is half an inch more either side than its official width so a 7 inch wheel would measure 8 inches. I use two sliding squares with the ruler part clamped together in the middle. This should get you the full width of the wheel. Now work out half this amount. Bare in mind wheel widths are usually measure in J ie inches. You need it in mm. Using your sliding squares again mark off this half way point. Now measure from the back face of the centre of the wheel to this middlepoint you have marked. This is your offset in mm.
Old Aug 21, 2010 | 09:16 AM
gus's Avatar
gus
cheers for that my man
yep got that
Old Aug 21, 2010 | 09:44 AM
lead_foot's Avatar
lead_foot
is awesome
The lower the offset, the more pussy you get.
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
