Compression Ratio, How?
Old Jan 17, 2005 | 11:39 PM
Steve200+'s Avatar
Steve200+
Default Compression Ratio, How?
Except for calculating things (which I'm not terribly good at), how can I find out what C/R my engine is running? I've got a couple of different setups to swap around, and I could do with testing each one.....
Old Jan 18, 2005 | 01:26 AM
Steve200+'s Avatar
Steve200+
May be being thick here, but there's got to be some means of measuring the chamber volume without major hassle?
Anyone??? lol
Old Jan 18, 2005 | 01:43 AM
CraigN's Avatar
CraigN
not accurately without taking apart the engine and measuring bore stroke etc and working it out
somoene with experience maybe able to give a guestimate by the figures you get with a compression test
Old Jan 18, 2005 | 07:09 AM
AlexF's Avatar
AlexF
www.afracing.com/cr.xls
Old Jan 18, 2005 | 09:34 AM
ON-UJAH's Avatar
ON-UJAH
http://www.dunegoon.org/compression.html
If it is a standard engine you will be able to research things like bore, stroke, rod length, compression height, combustion volume and deck height. If not you'll know at least some so can get a rough idea of CR.
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
