Easy bleed...........
Old Apr 25, 2010 | 06:07 PM
snoopaloopa's Avatar
snoopaloopa
Default Easy bleed...........
Anyone used them got opinions on them, looking at getting one of the non-return valve types rather than the vacuum ones. Just think it would make life a lot easier if they actually work?
cheers
Old Apr 25, 2010 | 06:14 PM
burnzy's Avatar
burnzy
burnzy
do you mean just the hose with a non return valve on the end?
if so there shite and more hard work than there worth, i got a cheap sealy pressure bleeder off ebay its better made than the ezi bleed ones and only about £15 iirc so cheaper too , just connect it upto a spare tyre or summit at about 25-30ish psi iirc and go round the car doing all the bleed nipples it's so much easier, remember tyo not loosen the bleed nipples off too much as it can suck air through the thread and give a false reading of air still being in the system
Old Apr 25, 2010 | 06:24 PM
martysmartie's Avatar
martysmartie
What he ^^ said, I have same one made by Gunson, just put fresh fluid in provided resivour and then connect to spare tyre to pressurise meaning you only need to concentrate one one thing and that's on bleeding from nipples and ABS if your car has it.
Martin
Old Apr 25, 2010 | 07:06 PM
s1cab's Avatar
s1cab
as above used the gunson one for years now cant fault it.
Old Apr 26, 2010 | 06:38 PM
snoopaloopa
Excellent, cheers guys
Old Apr 26, 2010 | 06:51 PM
20fiesta09's Avatar
20fiesta09
great bit of kit, only thing is make sure there is the right cap for your master cylinder!
Old Apr 26, 2010 | 07:24 PM
Madbradz's Avatar
Madbradz
Brilliant piece of kit! Cant rate them enough!
Old Apr 26, 2010 | 07:37 PM
Ginge !'s Avatar
Ginge !
just finding my feet
yeah, they aint made for jap cars !!!!
Old Apr 26, 2010 | 08:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the BEST bit of kit i ever bought was a £28 vac bleeder off ebay the other week!!
if you have a compressor, get one.
i reckon 20 mins to bleed all callipers, and mine are all 4 pots so 8 nipples!
Old Apr 26, 2010 | 08:45 PM
martysmartie
If it's for the Cosworth in your siggy there is a cap for this, as well as for older master cylinders.
Martin
Old Apr 26, 2010 | 11:13 PM
Sp3no's Avatar
Sp3no
Used my Gunson pressure bleeder yesterday for the first time after years of using a non return valve type. OH MY GOD so easy, why have i not owned one of these sooner. Bleeding brakes is my pet hate. Not any more its a breeze
Old Apr 27, 2010 | 06:13 AM
snoopaloopa
I have ordered the gunson one from good old fleabay so if it arrives I shall give it a go at the weekend
I have the discs all round non-abs master cylinder on and the guy reckons it will fit fine so heres hoping
Old Apr 27, 2010 | 12:41 PM
martysmartie
Can confirm there is a cap for the smaller reservoir non ABS master cylinder.
Martin
Old Apr 27, 2010 | 12:43 PM
Rab's Avatar
Rab
Fucking superstar........
There's NOTHING easy about an eazibleed..... Best bet is to get someone to mash the pedal for you.
Mark RS
Oct 12, 2015 06:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jc1989rs
Sep 18, 2015 07:05 PM
