Code P0171
Old Mar 29, 2010 | 01:29 PM
DMR's Avatar
DMR
Default Code P0171
Car has been playing up for past couple days and today got very bad. it will struggle to start and seems to need a jump start from another car to get going sometimes manages it itself. It idles fine but under any load will cut out. hesitating and spluttering while running. go round a corner and it will very nearly cut out or die either way no power at all. if i get the car running and put my foot down it will rev ok but no increase in speed at all
It's a ford focus 1.6 auto and the fault code is P0171 it's in the garage now having a live feed to get a better idea of whats what but thought i would see how smart you guys are and what ur thoughts are.
Old Mar 29, 2010 | 03:23 PM
iansoutham's Avatar
iansoutham
OCD Victim
Code 0171 is a generic one for running too lean. Probably an air leak.
Old Mar 29, 2010 | 09:23 PM
DMR's Avatar
DMR
hoping it is just an air leak but guessing my luck it's doubtful
Old Mar 29, 2010 | 09:34 PM
bouncy's Avatar
bouncy
MAF sensor or air leak after MAF
Old Mar 29, 2010 | 09:39 PM
DMR's Avatar
DMR
i read somewhere u can test the maf sensor but i couldn't remember at the time. So i unplugged it and tried starting it but with no difference at all. is there a test to see if it is at fault?
Old Mar 29, 2010 | 10:02 PM
botters's Avatar
botters
competant bodger
had ecact same symptoms on a focus at work it turned out to be the plastic manifold had a crack in it, i was spraying brake cleaner around the manifold to see if the revs would rise to show an air leak and it would not but on removing the manifold i saw it had a very fine crack underneath fitted a new manifold and it was perfect hope this helps
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
