Compomotives - changing offset
Old Mar 7, 2010 | 09:24 PM
Rick's Avatar
Rick
Default Compomotives - changing offset
Are all comps of the same PCD made from the same blank?
i.e. if i had some pug fitment ET15's, could i take 20mm of the face and have enough meat to make them suitable for Ford?
Rick
Old Mar 7, 2010 | 10:13 PM
THE RADMAN's Avatar
THE RADMAN
no,you wouldnt have anything left for the mounting bolts,the smaller the et the deeper the bolt holes are drilled,if you took 20mm off the backs your bolts would drop straight through the holes
Old Mar 7, 2010 | 10:24 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i had someone wanting to buy a set of wheels from my old mk4 escort, we tried them on the car and the rears would not go on, as the wheel hit the inner arch before the hub.
pug wheels on an escort tho, should go on but might stick out a bit lol
if its local, id do a trial fit!
Old Mar 7, 2010 | 10:28 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
so looking at the positive offset pic, the distance between wheel centre and the hub face is 15mm for the pug wheel. the ford is 37 or whatever, so witht he pug wheel fitted, the outside edge will stick out further than the wing, but probably look 100% better than the gay offset a ford usually comes with
Old Mar 8, 2010 | 08:47 AM
Rick's Avatar
Rick
It may look ok, but useless if your arch is cutting straight into the tyre lol
Old Mar 8, 2010 | 09:39 AM
jonny s2's Avatar
jonny s2
et15 will be ok just give it a more wider stance, how wide are they? 7"
Old Mar 8, 2010 | 09:49 AM
Rick's Avatar
Rick
not sure to be honest!
Old Mar 8, 2010 | 12:08 PM
Ade's Avatar
Ade
Fast Ford snapper
Low offset is goooooood!
Roll the arches, get it decked, add decent width and offset = any car looking cool
Old Mar 8, 2010 | 12:19 PM
.Ross.'s Avatar
.Ross.
Am sure Dicko(&Sarah) Had his Milled down to fit a SAFF?????????? Although, Not sure how much was removed.
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
