HELP HELP!!!!!!!!
Old Jan 20, 2010 | 08:34 AM
ryley11's Avatar
ryley11
Default HELP HELP!!!!!!!!
jus changed a spring on my fiesta ,got the spring on ok but cant get the shockie back in the hub and then my driveshaft popped out from gearbox on drivers side .wat a mess and i need back on the road asap , wat should i do ? any mechanics online
Old Jan 20, 2010 | 08:44 AM
Conor Harrington's Avatar
Conor Harrington
could be an easy fix mate if your unsure jsut call out your break down cover
or if not get a mobile mechanic might be costly as least you will know whats beein dun it all right
but im sure some one on here will give you a guide on how to do it.
Old Jan 20, 2010 | 10:21 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
the driveshaft will just slide back into the gearbox,but you will need to top up the oil if you have lost any,
on the hub,where the bolt goes.you can open the hole a little by knocking a large screwdriver or small chisel into the gap.this will make it easier to fit the shock back in.dont hit it too hard and break the hub.
Old Jan 20, 2010 | 10:43 AM
utternutter's Avatar
utternutter
you could also try a jack under the hub putting pressure to slide the two together, good few wacks with a hammer she should slot in, make sure doesnt go to far as it only needs to go to a certain point to put the bolts through
as above with the shaft pop it back in
