Ext wastegates-explain?
Old Dec 30, 2004 | 08:33 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default Ext wastegates-explain?
Ok, pretty unsure how these work and when one is needed on a car if at all so would like a simpleish explanation if anyone is able
Im not all that confident in how one works so im not gonna embarass myself by explaining the way i think it does
can you tell if a car has one by the sound it makes when its open? i know it has its own branch on the manifold aswell, is it connected to anything else?
EXPLAIN
Old Dec 30, 2004 | 08:44 PM
Graceland's Avatar
Graceland
Team HOTHOT!
essentially, it goes on the exhaust manifold and a valve opens at a set pressure and lets exhaust gas out of a seperate pipe - whcih may or maynot be connected to the exhaust system, and this exiting exhaust gas does not go via the turbo and this keeps the speed of the turbo constant for the desired boost pressure/rpm of engine
thats a simple way of looking at it
Old Dec 30, 2004 | 08:51 PM
vroooom ptssssh
It Wasnt Me!
lol cheeRS mate, that's explained the basics atleast!! so what happens to the existing wastegate etc? and how does it build up pressure when u'd think it'd just keep boosting with no actuator?
Old Dec 30, 2004 | 08:52 PM
Graceland's Avatar
Graceland
Team HOTHOT!
the external wastegate has an actuator of sorts - it controls the valve that vents xhaust gas
Old Dec 30, 2004 | 08:56 PM
rsnissan's Avatar
rsnissan
You use them on tubbys without an internal gate i.e tubbys that are designed to be used with an external gate.
pressure builds up and hits an adjustable spring this defines when it opens to let the exhaust gasses by pass the tubby
Old Dec 30, 2004 | 09:03 PM
vroooom ptssssh
It Wasnt Me!
but how does the pressure build up if the tubby has no actuator and the revs keep rising and exh gasses flow? lol do these tubbys with no actuators have no wastegates i take it?
Old Dec 30, 2004 | 09:18 PM
rsnissan's Avatar
rsnissan
yes as i said before they have no internal gate
Old Dec 30, 2004 | 09:28 PM
vroooom ptssssh
It Wasnt Me!
ok oop ssorry
Old Dec 30, 2004 | 09:35 PM
rsnissan's Avatar
rsnissan
ok...................now dont let it happen again
Old Dec 30, 2004 | 09:37 PM
vroooom ptssssh
It Wasnt Me!
Old Dec 30, 2004 | 10:49 PM
murfs frst's Avatar
murfs frst
just out of intrest how much would this cost
Old Dec 30, 2004 | 10:52 PM
depends on the car and what you are doing.
if you have an internal gate and arent running stupidly high power though you dont need one
Old Dec 30, 2004 | 10:53 PM
Alps Pacino's Avatar
Alps Pacino
whats the advantage then smoother more controlled boost?????????
Old Dec 30, 2004 | 10:54 PM
the amount of gas you can flow is the main advantage
Old Dec 30, 2004 | 10:59 PM
Alps Pacino
_________________
so what type of boost does a normal internal wastgate give up at, or is it not that simple say a -31 for eg
Old Dec 31, 2004 | 01:51 AM
vroooom ptssssh
It Wasnt Me!
keep it commin
Old Dec 31, 2004 | 01:56 AM
_________________
not that simple, its not about how much boost, its about how much excess gas you have to get rid of which is a lot to do with the turbo spec and rpm the engine is doing compared to how much boost you want.
on most engines, at full power, there would be little or no gas to flow anyway as the turbo would be barely coping with making the boost anyway.
PS
Nitrous is when they are REALLY useful, to avoid massive spurts of extra boost.
Old Jan 1, 2005 | 08:55 PM
vroooom ptssssh
It Wasnt Me!
So are they really only needed with bigger cc engines that can rev high using large turbos? what size of turbo would u reccomend using one? or with nitrous/turbo cars ?
