Pc help required please
Old Nov 23, 2009 | 08:00 PM
Lee Reynolds's Avatar
Lee Reynolds
Default Pc help required please
Something and nothing i think, or is it?
My pc, like others id imagine, goes into standy mode. The fan stops and its like it is switched off, and just pressing any key fires the fan back up and in seconds the screen is back on.
Lately though, the fan stops as it goes into standby mode, but immediatley its as if someone has pressed a key and it fires back up!
Any ideas? No we havent got a ghost lol!
Old Nov 23, 2009 | 08:02 PM
Escow-Van's Avatar
Escow-Van
Have you updated any drivers recently? One of my work laptops did this and blamed the keyboard driver for some reason
I guess you don't get an error message?
Old Nov 23, 2009 | 08:32 PM
rich123's Avatar
rich123
do you have a cd in the rom it may do that when u have a cd in the rom
Old Nov 23, 2009 | 09:07 PM
Lee Reynolds
Yes i do at the mo Rich, but im 99.9% sure it was doing it without one in. Ill check that though cheers
Escow-van, no mesage mate no!
Old Nov 24, 2009 | 03:55 PM
Lee Reynolds
Well, its not the cd rom thats the prob
Old Nov 24, 2009 | 04:16 PM
Daveyboy's Avatar
Daveyboy
you could always have a play around with the power options in control panel. configure it to do different things when you open/close the lid or press buttons etc....
Old Nov 24, 2009 | 09:30 PM
Lee Reynolds
Will have a look but even though im not bad with comps, im not that good either Cheers
Old Nov 24, 2009 | 09:33 PM
RichieST's Avatar
RichieST
Could be a dirty mouse ball/laser depending on what sort of mouse you've got. The slightest movement in the mouse will turn it back on.
Go into power options and change it to go to standby, then you need to press the power button on the front of the machine to make it wake up!
Old Nov 24, 2009 | 09:42 PM
Lee Reynolds
Will look at that cheers rich!
Old Nov 25, 2009 | 12:59 PM
Lee Reynolds
Changed the setting for the power button, changed it to make the pc sleep rather than shut down. As soon as it went to sleep it fired straight back up!
Think my comp has insomnia!
Old Nov 25, 2009 | 01:26 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
has it got a virus?
Old Nov 25, 2009 | 01:43 PM
Rick Astley's Avatar
Rick Astley
Never gonna give you up!
It's quite possible that it's your ethernet adaptor causing the problem.
If you go to Start menu type in devmgmt.msc into the search box, then press continue, when the window loads look for Network Adapters, then look for Ethernet, right click on ethernet, go to properties, then power management, look for a tickbox with text alongside saying allow this device to wake the computer. If it is ticked, untick it.
Also check your wireless card to see what power settings that is on also.
Old Nov 25, 2009 | 09:57 PM
SS1's Avatar
SS1
On power options set the pc to PRESENTATION via your POWER SCHEMES scroll down options
Then the pc should never go into standby mode
If it does your problem lies elsewhere
Old Nov 25, 2009 | 10:23 PM
Lee Reynolds
You could have saved the day there matey Checked it and it was set to wake computer!
Will see when i log off tonight if its worked
Old Nov 25, 2009 | 10:36 PM
SS1's Avatar
SS1
Also try this free program for 30 days
http://www.tune-up.com/products/tuneup-utilities/
ive got the free key-gen number for the 2009 edition AWESOME SOFTWARE
just enter your email addy no spam or shit after the free download
it will still fix all errors before the 30 day period
Old Nov 27, 2009 | 04:57 PM
Rick Astley
Go on then Lee, did it fix it?
Old Nov 27, 2009 | 05:56 PM
martysmartie's Avatar
martysmartie
This will almost certainly be the right answer and would be my first suggestion as well also make sure you are not placing mouse on shiny surface if optical, NIC could cause this but unless you have connected the NIC or changed it's config recently you would have experienced the problem before. Changing what the power button does certainly won't be the remedy.
Martin
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
