JB Weld
Old Dec 30, 2004 | 12:20 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default JB Weld
What it for?
I went n bought some araldite earlier n saw it, and recognised the name, but read the packet n wasnt 100% what its for?
Is it a REALLY strong filler, or a REALLY strong glue, or both? Or?
The yank writeup on it seemed to contradict itself.
Is it better than araldite if it is a glue? They about the same price...
Old Dec 30, 2004 | 12:25 AM
Ginge !'s Avatar
Ginge !
just finding my feet
its a very very string adheisivem can stick metalk too but not sure how thiough
i know use it to stick the nuts and bolts on display at work so the dont wal off and stuck a 20p coin near the staircase with it too ( gotta love kids )
Old Dec 30, 2004 | 12:27 AM
Billabong's Avatar
Billabong
JB Weld is the brand, there's different types of product, but basically it's an adhesive.
http://www.jbweld.co.uk/files/prodb.html
Old Dec 30, 2004 | 12:32 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Stronger than araldite you think? That stuff is fuckoff strong
Old Dec 30, 2004 | 12:33 AM
Ginge !'s Avatar
Ginge !
the stuff at work is like chemical metal
Old Dec 30, 2004 | 12:36 AM
Billabong's Avatar
Billabong
No idea myself, although Araldite is used in some tough applications. Don't like the JB Weld comment about
The adhesive has been designed to effectively replace traditional welding, soldering and mechanical jointing methods in the joining/repairing of rigid surfaces including all metals, wood, glass and ceramics.
... it could give DIY'ers some strange ideas
Old Dec 30, 2004 | 12:38 AM
Ginge !'s Avatar
Ginge !
why seam weld when ya can jb weld ya mean
oh and araldite is a brand name too btw
Old Dec 30, 2004 | 12:40 AM
Billabong's Avatar
Billabong
LOL @ Bal Exactly (although knowing my luck, it probably could be used for that though I think I'd prefer the traditional way)
Yep, meant to add that also.....
What are you intending to do with it Steve?
Old Dec 30, 2004 | 12:41 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
On the diagram on the back of the JB weld packet it shows it used on either an cracked engine block or gearbox casing if i remember right
Im sure it shows them glueing snapped cogs back on too
Old Dec 30, 2004 | 12:44 AM
Billabong's Avatar
Billabong
If you read their link I posted, it does mention engine repairs, and temp's it can withstand, it can be machined/drilled once cured etc...
I wonder if I could make a custom cam using that stuff, or repair a melted piston etc.. bosh some on it, bit of grinding and good as new
Old Dec 30, 2004 | 12:49 AM
Ginge !'s Avatar
Ginge !
jb weling in a roll cage
halford sell cracked block repair for 10 quid ( wish i was liying, im not
ya stickm in in the oil filler car or the water, why spend a 4 grand on a rebult with a tuner when all ya need it halfords cracked block repair fluid
Old Dec 30, 2004 | 12:53 AM
mark's Avatar
mark
jb weld is ok i used it to patch up a coreplug that holed got me home ok and then to the garage
shame id warped the heads b4 i notist the leak tho
Old Dec 30, 2004 | 05:24 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Some people use it for reshaping ports on ally heads.
Old Dec 30, 2004 | 06:03 PM
white cab's Avatar
white cab
stick some of that on you cracked block and run 30psi on it see how good it is then LOL
Old Dec 30, 2004 | 07:05 PM
phil4x4saph's Avatar
phil4x4saph
It depends what your expectations are?!
If your old Dorris's Nissan Micra looses a bit of water and she wants it to live for another 6 months then its great
Old Dec 30, 2004 | 07:07 PM
white cab's Avatar
white cab
i think vauxhall novas are made of the stuff LOL
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
