Quick Questions
Old Oct 22, 2009 | 09:15 AM
joffy's Avatar
joffy
SLOW LEARNER
Default Quick Questions
1st, When changing to mechanical tappets rather then hydraulic, do you have to change anything else apart from the cams?? ie guides, stem seal etc
and 2nd, if im fitting a set of gauges and i want to be able to dim them on the same circuit as the rest of the dash,(hope this makes sense) does anyone know what wires i need need to connect to off the back of the dimmer switch?? (its a three door cossie if its any help)
many thanks for any info
Old Oct 22, 2009 | 04:29 PM
You DON'T need to change the cams at all when going from hydraulic to mechanical profile.
If as I assume a yb just need 1.8D buckets and shims, direct fit.
To dim the clocks with the others, you can simply hook into the illumination wire, which I think is grey/yellow, but prod with multimetre to determine.
Old Oct 23, 2009 | 09:00 AM
joffy's Avatar
joffy
SLOW LEARNER
tabs your a legend
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
