bleeding brakes
Old Oct 4, 2009 | 08:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default bleeding brakes
i have a bias pedal box, braded lines no abs etc and evo 8 callipers all round.
so if i just open the bleed nipples and let gravity do its work, will this get ALL the air out, as i have no mates to pump the pedal for me
last time i bled them it seemed to work ok, but i want to be sure it get all the air out.
cheers
Old Oct 4, 2009 | 08:44 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Make friends!
Old Oct 4, 2009 | 08:48 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Get an eezibleed!
Old Oct 4, 2009 | 08:50 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
should gravity bleed but wount b perfect
Old Oct 4, 2009 | 08:51 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Originally Posted by Mal.
Get an eezibleed!
got one of those but it doesnt fit the reservoirs properly and pisses brake fluid everywhere. also got a one man bleed kit and thats a waste of time too...
Old Oct 4, 2009 | 08:52 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well if it will do most of it, ill drag the missus out and put her to use lol
Old Oct 4, 2009 | 08:54 PM
Dangerous Malcolm..
Have ya got access to an air compressor?
Old Oct 4, 2009 | 08:59 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes, got a 40 or 50l one.
ill blow the fucker up if i hooked that up tho
Old Oct 4, 2009 | 09:01 PM
Dangerous Malcolm..
Get a thingy and suck it through!
Old Oct 4, 2009 | 09:04 PM
wulliesxr4i
GIT-R-DONE
yeah it should get u a fairly good brake mayb a lil spongy but get the missus out she will manage it,
i normaly gravity bleed then 1 wheel at a tym then get the girl to come finish it off lol
Old Oct 4, 2009 | 09:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mal, i dont have a 'thingy' and my compressor only blows, unfortunatly it wont suck
wullie, i guess thats the best plan!
Old Oct 4, 2009 | 09:12 PM
Dan1281's Avatar
Dan1281
i modded on old master cylinder cap of the transits that we have so that i can set it to 10psi and it bleeds up a treat
Old Oct 4, 2009 | 09:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think the reservoirs are slight smaller than most as the cap just wont go tight.
it should be ok to do what i have said tho lol
Old Oct 4, 2009 | 09:22 PM
wulliesxr4i
GIT-R-DONE
yeh am sure u will mate, if not got a steering rack gaitor nd put a tyre valve in the small endnd put a jubilee clip on it then get a jubilee clip over then big end and tightin it up on the top of the resevoir nd stick some air in it nd u got a good pressure bleeder lol
Old Oct 4, 2009 | 09:26 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
great idea, i have som gaitors and a valve somewhere.
just a big letdown that i cant get to the reservoirs to attach it
they are mounted under the dash with the caps level with the top of the dash lol..
Old Oct 4, 2009 | 09:28 PM
wulliesxr4i
GIT-R-DONE
lol its alway the same mate am sure ul manage it, get the misses to help
Old Oct 4, 2009 | 09:51 PM
1098's Avatar
1098
FIESTAHH
Originally Posted by Will @ M Developments
Make friends!
Get one of these
or one of these
Old Oct 4, 2009 | 10:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
when you pump the pedal to build up the pressure, the air will go to the top, and then you can let it out rather than just the fluid coming out
so yes, get the wife to help you, she only has to sit there and press the pedal, my mum says it reminded her of using an old sewing machine, so you oculd always make that comparison
Old Oct 4, 2009 | 10:58 PM
stevieturbo's Avatar
stevieturbo
C**t
stick a pipe over the bleed nipple and suck
Old Oct 5, 2009 | 12:45 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Fudgey give me a ring, can give you a hand weds or thurs night.
Old Oct 5, 2009 | 09:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers for the offer wil, but week nights are not much good for me, as like tonight i got in at 9.15pm... and left at 6.15am....
so weekends only really, and thats if i get chance
Old Oct 5, 2009 | 09:06 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
you ever had brake fluid in the mouth?
not good
Old Oct 5, 2009 | 10:32 PM
Big Will_'s Avatar
Big Will_
not good
I'm sure you've had worse in there
Old Oct 6, 2009 | 08:29 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
twat
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
