ABS System testing
Old Jul 21, 2009 | 08:23 AM
kiwikermit's Avatar
kiwikermit
Default ABS System testing
Does anyone have any info on testing the ABS on a 2wd saph? My pesky ABS light is on again. I have checked and cleaned wheel sensors seeing as this seems to be the most common fix but no change... If i can't find info on testing and fault finding, i guess i just start throwng parts at the car... I can hear the pump run for 20 seconds or so before the buzz slows and stops. Any help appreciated.
Old Jul 21, 2009 | 11:56 AM
jon@work's Avatar
jon@work
Couple of common issues for you to check out first :
Wheel Speed Sensor Circuits
1. Ensure ignition switched off
2. Disconnect ECU multi-plug
3. Connect ohmmeter between harness multi-plug terminals listed below:
o LHF: 7 and 25
o RHF: 5 and 23
o LHR: 4 and 22
o RHR: 6 and 24
4. Resistance should be 900 to 1400 ohms
5. If resistance not as specified:
o Disconnect the appropriate wheel sensor from the car loom.
o Measure resistance across wheel sensor at plug on end of sensor.
o If outside above range, replace wheel sensor.
o If OK, check wiring between sensor connection and ECU.
Checking the Low Brake Fluid in Reservoir Warning
1. Remove the 2 pin connector from the brake fluid level reservoir. Ignore the 3 pin connector.
2. Without removing the reservoir cap, check for continuity across the 2 connector terminals on the cap. Lack of continuity across these terminals indicates low brake fluid, and disables the ABS.
3. If no continuity, top up reservoir with brake fluid as required. If fluid level OK but no continuity, buy a new cap. As a short term measure to diagnose reservoir cap failure, bridge the terminals of the wiring loom connector that fits to the cap with a short piece of wire and test drive.
Let us know how you get on.
Old Jul 21, 2009 | 07:13 PM
kiwikermit's Avatar
kiwikermit
Cheers Mate, I'll give it a try in the next couple of days and get back.
Old Jul 23, 2009 | 07:08 AM
kiwikermit's Avatar
kiwikermit
Smile
All good. I Checked the Resivoir cap first seeing it was the easiest thing to check. I bridged the plug with a bit of fuse wire and presto, the light went out. i have sourced a replacement for a reasonable price and it will be on my door step next week. Thanks for the help.
Old Jul 23, 2009 | 10:10 AM
jon@work's Avatar
jon@work
no problem
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
