knife edging ????????
Old Dec 13, 2004 | 08:28 PM
jakki's Avatar
jakki
Default knife edging ????????
has anyone had there crank knife edged on a 4x4 cosworth????if so what do u think ????????
Old Dec 13, 2004 | 08:31 PM
Alps Pacino's Avatar
Alps Pacino
there seems to be more and more norther monkeys poping up on the board, as for the knife edged crank i dont have a clue
Old Dec 13, 2004 | 08:32 PM
brad's Avatar
brad
its not something you can really notice tbh
it just gives less resistance as the crank hits the oil in the sump . but you probably allready new that
pugo's Avatar
pugo
i done mine on my 2wd saff
I did it as a matter of course when i built the engine!!!!!!!
I think every little helps
Old Dec 13, 2004 | 08:39 PM
jakki's Avatar
jakki
cheers folks
Old Dec 13, 2004 | 08:40 PM
brad's Avatar
brad
oi rudey
read my thread for you
i had knife edging done on my shaff , but i think they have to be carefull not to take too much off or it becomes weak
EscortWRC's Avatar
EscortWRC
It is much more common on NA engines than on turbo ones.
Personally I"d worry more about having the rotating assembly dynamically balanced than I would knife-edging the crank....but as always, YMMV
Old Dec 13, 2004 | 08:41 PM
Ryan's Avatar
Ryan
the crank arms (or lobes) are machined on the edges to make the crank cut through the oil better. Also less weight
I think thats correct
Well i know what is done and whats it done to, hard to explain, but im pretty sure thats the reason aswell
Old Dec 14, 2004 | 03:39 PM
GARETH T's Avatar
GARETH T
dont bother on a cossie, for one simple reason
ave a look where the oil is on a cossie and where the crap swings
Old Dec 14, 2004 | 03:46 PM
wes's Avatar
wes
Time to show these pictures again for the "it makes the crank cut through the oil faster" believers Gareth
(my own work )
I beleive it's done so you have less recipricating (SP?) mass i.e. it makes it rev faster
Old Dec 14, 2004 | 03:47 PM
Fast Guy's Avatar
Fast Guy
Fit a crank scraper if you're worried about knife edging the crank, that's assuming anyone has made one for a Cossie?
Old Dec 14, 2004 | 03:54 PM
CabrioTurbo's Avatar
CabrioTurbo
Really not the best idea IMO to be removing lots of meat from the crank.. esp when it is taking such a large ammount of power all in one go...
Knife edging is done mainly on N/A engine to help them rev harder... this isnt needed or applicable on a turbo charged engine and is therefore of no use..
Old Dec 14, 2004 | 03:55 PM
Useful on high revving motors where the crank is buried in the sump.
Cant see the point on a cossie though.
It will NOT make the crank more likely to fail though, less material doesnt always equal weaker, and in fact you only have to look at smoothing metal off like con rods (ie really heavy polishing) and you can see that often less metal is in fact stronger.
Old Dec 14, 2004 | 03:57 PM
Fast Guy's Avatar
Fast Guy
I saw an experiment in a magazine back in the late 80s early 90s and they put a perspex window in a sump so you could seee what was going on and the crank acted like an egg whisk, with alot of oil trapped in the rotating assembly like when you whisk an egg.
Knife edging will make it more aerodynamic so in theory is should cut through the air/oil/blowby gasses or whatever else is there more effectively.
Old Dec 14, 2004 | 04:14 PM
you can only make a dramatic improvement in terms of not churning up the oil too much if it does it in the first place though of course!
andyrs1600i
Apr 29, 2026 03:21 PM
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
hopper350
Sep 4, 2015 12:53 AM
YODI
Aug 30, 2015 01:12 PM
