Which Memory for an old PC
Old Dec 8, 2004 | 08:44 AM
dvid's Avatar
dvid
Default Which Memory for an old PC
Hi guys,
This is a real basic question but what memory is likely to be needed for an old PC which currently runs Windows 98, that I am upgrading to XP. It is a 733mhz (just enough to run XP) and must be about 4 years old, I can only see DDR memory around but I am sure there are other types, guess the easiest way is to take old memory out and have a look? Also is there any way of telling whether the PC will read both sides of the memory I buy (gonna get 512 to make it 638 in total)
Any advice would be Cheers guys!
Old Dec 8, 2004 | 08:56 AM
Graceland's Avatar
Graceland
Team HOTHOT!
well it wont take 72 pin simms as they are ainchant, it'll take more than likely, 144 pin dimms (dual inline memory module) - cheep enough from computer fairs in 128 meg sticks
Old Dec 8, 2004 | 08:58 AM
Jim Galbally's Avatar
Jim Galbally
as per gracey...
commonly refered to as PC133 or PC100
Old Dec 8, 2004 | 08:59 AM
dvid's Avatar
dvid
any good websites I can order from? I was looking on www.overclockers.co.uk which I normally use and it all seems the same Im such a Doofus lol
Old Dec 8, 2004 | 09:00 AM
Dan B's Avatar
Dan B
Count the pins, I'm afraid......it could be 168-pin SDRAM.
SDRAM (168-pin)
If it's REALLY ancient, and the memory is in your computer in pairs, it could well be SIMMs (72-pin), in which case:
SIMMs (72-pin)
Old Dec 8, 2004 | 09:01 AM
dvid's Avatar
dvid
ok cool cheers people... I'l whip the old memory out and take a look
Old Dec 8, 2004 | 09:07 AM
Graceland's Avatar
Graceland
Team HOTHOT!
www.ebuyer.co.uk - they seem to have some good deals on memory at the moment
also good deals on flatscreen monitors too on there - 19" tft for 270 quid
Old Dec 8, 2004 | 09:09 AM
Jim Galbally
i doubt very much it'll take SDRAM if its a 733mhz PIII (or equivanent!)
Old Dec 8, 2004 | 09:10 AM
dvid's Avatar
dvid
I was assuming DDR but I will soon find out I guess! thanks for all your help.... give this site a top name!
Old Dec 8, 2004 | 09:57 AM
Jim Galbally
DDR is SDRAM and is refered to as PC2100 PC2300 PC 2700 etc. etc.
ps a pentium 3 733 chip has a 133mhz FSB so you'll need PC133 memory
preferably buy in pairs too (so if you want 512, but 2x 256mb DIMMS)
Old Dec 8, 2004 | 10:01 AM
dvid's Avatar
dvid
ok cool it is definately a 733mhz not sure if its Pentium or celeron / athlon....
Can i ask why buy in pairs? (only cos its more expensive lol )
Old Dec 8, 2004 | 10:03 AM
Dan B's Avatar
Dan B
Why pairs? Unless my memory (no pun intented) serves me incorrectly, you haven't needed to pair memory since SIMMs went out of fashion...
Old Dec 8, 2004 | 10:10 AM
Jim Galbally
you don't NEED to, it just gives a performance gain...
mainly noticeable on DDR stuff nowadays, but even with the old EDO stuff it still helps
Old Dec 8, 2004 | 10:11 AM
CraigN's Avatar
CraigN
jim you cock
pc 133 is SDRAM DDR is not SDR = Single data rate
for a 733mhz pc you definately want PC 133 SD RAM memory module
SO DIMMS have not been used since the days of SUB 100mhz PC'S
anything on this page will be ok
http://www.novatech.co.uk/novatech/p...x1y0z1p0s0n0m0
oh and you have no need to buy in pairs
it makes no differencce. on newer dual channel equiped motherboards running DDR dual channel is faster but it will make no difference on yours.
Old Dec 8, 2004 | 10:15 AM
CabrioTurbo's Avatar
CabrioTurbo
jim are you sure!
SD ram is pc133 not DDR
Old Dec 8, 2004 | 10:17 AM
dvid's Avatar
dvid
jim you cock
A bit Harsh!
Cheers guys for clearing this up, anythingon that page you reckon? Seems a cheap site too!
Old Dec 8, 2004 | 10:21 AM
CraigN's Avatar
CraigN
its not harsh
jim is sposed to be a PC keener
anything on that page will do just pick the size u require
check inside your pc to see how many slots you have available and the max memory your motherboard can take
a lot of P3 motherboards couldnt take over 512mb
Old Dec 8, 2004 | 10:25 AM
Jim Galbally
jim you cock
craig, i know (in great depth) how memory works and which type is which and what theyre compatible with.
unfortunately people call a lot of things by the wrong name, which is why smart arses often try to correct you when refering to things by what theyre commonly refered to, (ie not what they truly are)
but lets nitpick at this for a sec...
well considering they work in conjunction with 150 FSBs that'd be a bit silly now wouldn't it... sure youre not refering to SIMMS (single inline memory module) which are the 30something and 72 pin jobbies we all used to use
PC 133 is NOT the same as DDR266 (PC2100) even tho they work at the same clock rate
PC133 is a 144pin Dual inline memory module which is Extended Data Output type
you're confusing acronyms...
Synchronous Dynamic Random Access Memory
vs
Single Data Rate
we're on about connection types (ie 168pin connections) which is commonly refered to as SDRAM type, dont confuse the SDR part of the name
Old Dec 8, 2004 | 10:27 AM
Jim Galbally
oh and yes i can admit that PC133 is a type of SDRAM, but if you walked into any PC world and asked for SDRAM they'd hand you a 168pin stick
Old Dec 8, 2004 | 10:29 AM
dvid's Avatar
dvid
holy shit now Im confused! and im meant to be in 2nd line support for a worldwide company (its ok hardware department do all this gubbins, but before you say it yes an embarrassing lack of knowledge in this area!
im gonna go with Craigs page and memory type unless anyone has any objections!
CraigN's Avatar
CraigN
jim you cut a bit ofme off
i said
SO DIMMS
and thinking about it now that is laptop memory
i did mean
SIMMS
however you stil lgot it wrong
Old Dec 8, 2004 | 10:31 AM
Dan B's Avatar
Dan B
That's assuming FAR too much about PC World......if I went into PC World, and asked for SDRAM, they'd be more likely to point me at the software section or ask for a manager's advice!
And yes, to answer above "mis-corrections", DDR is a type of SDRAM
Old Dec 8, 2004 | 10:35 AM
Jim Galbally
i didn't get it wrong, i just didn't go into great detail as i didnt want to confuse the bloke...
i know exactly what is what, but 90% of people (especially those in retail!) don't.
SO many people think that SDRAM and DDR SDRAM are one and the same, whereas SDR SDRAM (ie "normal" SDRAM) and DDR SDRAM are not only different, they have different connections on them. If i was to talk into a shop and ask for a 256mb SDRAM stick with a 133 data rate, i recon that 9 times out of ten they'll hand me a PC2100 DDR SDRAM stick, as the sales assistant is likely to be 17 years old, and has probably never known anything different.
if you quote: PC133 (133mhz DATA rate) DIMM @ xxxMB you can't really go wrong
Old Dec 8, 2004 | 10:57 AM
Jim Galbally
vs
Single Data Rate
by the way, i re-read that twice and i can't understand what i meant please ignore as it doesnt make any sense... lol
Old Dec 8, 2004 | 11:01 AM
dvid's Avatar
dvid
Kam B
Sep 24, 2015 10:40 AM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
cfoster
Alloy wheels and ICE for sale
Mar 18, 2005 04:52 PM
soulweavers
Computers, Consoles and I.T.
Aug 1, 2004 09:03 AM
