castor angle
Old Jan 10, 2009 | 06:37 PM
andy escos's Avatar
andy escos
Default castor angle
can any one tell me what effect castor has on the handling of a car
Old Jan 10, 2009 | 06:42 PM
lead_foot's Avatar
lead_foot
is awesome
Caster =
* Maximise tyre contact patch during roll
* Improve turn-in response
* Increase directional stability
* Maximise tyre contact patch during braking and acceleration
* Improved steering feel and self-centre
* Increases dynamic negative camber (on turn)
Old Jan 10, 2009 | 06:44 PM
lead_foot's Avatar
lead_foot
is awesome
But
The more caster you have, the more straight-line stability and the more negative camber you get with steering lock and the outside wheel during cornering (with the inside getting positive camber). This aids turn-in, but you can go too far, which could cause drive shaft problems with a 4wd. Also it makes the steering heavier, so the above range is considered to give good straight line stability along with reasonably weighted steering and not too much camber change .
With positive caster, you also get some self centering of the steering wheel, which is a good thing for drifting (once on full lock, you can actually let go of the wheel, and it will naturally straighten ).
Rs1's Avatar
Rs1
Have a scan through this.....
http://www.lancerregister.com/faq/T01/t01.html
Old Jan 10, 2009 | 07:09 PM
andy escos's Avatar
andy escos
Originally Posted by lead_foot
But
how much is to much as i just had my geometry set but could only get castor set to 5,degrees positive to miss body work.
camber is 2.5 degrees negative
toe is 0.1
this is on a 4x4 cossy.
Old Jan 10, 2009 | 08:17 PM
lead_foot's Avatar
lead_foot
is awesome
Try
Between 3° and 5° of caster is considered the optimum.
On my own car, I run the following (track set-up):
Front:
Camber: 3° negative
Caster: 3° 30'
Toe-in: 2mm
Rear:
Camber: 2° 45' negative
Toe-in: 3mm
Old Jan 10, 2009 | 09:16 PM
andy escos's Avatar
andy escos
thanks 4 your help lead foot looks like i should be ok.
Fezman1
Oct 2, 2015 01:22 PM
landaqmabba
Sep 15, 2015 07:16 PM
JC
Aug 7, 2004 08:35 AM
neilm
Nov 3, 2003 12:39 PM
