boreing
Old Nov 28, 2008 | 06:39 PM
rs tingle's Avatar
rs tingle
Default boreing
hi there ppl i have a 200 block cosworth engine that needs boring i was wondering what pistons i would need after it had been bored or what choices would i have thanks
Old Nov 28, 2008 | 06:40 PM
LHD220Turbo's Avatar
LHD220Turbo
are you joking?
depends on how much is bored out! - what size is it at the moment?
or is this a trick question?
Old Nov 28, 2008 | 06:45 PM
rs tingle's Avatar
rs tingle
i was told it needs borein as it has a bit of a lip at the top ot the bore or does it just need re honeing its a standard engine just needing a rebuild .i dont now much bout boreing ect and if ya can do it with these engines info would be much apriciated thanks
Old Nov 28, 2008 | 06:48 PM
LHD220Turbo
boreing is basically makeing the holes where the pistons go bigger - so the piston size will depend on how bad the bores are and how much is bored out
unless you are going for silly power; standard mahle pistons will be enough
edit to say: if its just a lip, you could probably get away with a hone - best off taking it to someone who knows what they are talking about IMO
Old Nov 28, 2008 | 06:52 PM
rs tingle's Avatar
rs tingle
is there anywhere i can get it checked over in birmingham thanks for the help mate
Old Nov 28, 2008 | 07:05 PM
LHD220Turbo
if you want it checked and built for you; take it to Reyland
if you just want the machining work done; take it to a company called halesowen engines
Old Nov 28, 2008 | 07:11 PM
rs tingle's Avatar
rs tingle
i now relyland but i aint got that sort off muni to spend ya see .i heard alot about the haslowen engines cool ill go see em .im trying to save as much cash as i can buy doing it myself ya see iv done a bottom end bearings be4 but never changed pistons an such.
Old Nov 28, 2008 | 08:21 PM
rs tingle's Avatar
rs tingle
how much would a rebore cost me
Old Nov 28, 2008 | 08:29 PM
LHD220Turbo
all depends on who you use; but i'd expect between Ł80-Ł120
Old Nov 28, 2008 | 08:58 PM
B16CVH's Avatar
B16CVH
No point just honing the bores and fitting new std size pistons (if thats what they are at the moment) as bores wear oval from front to back, go for +0.5mm and you will be just fine.
I can get the block bored with torque plate for Ł100 cash but you would need the pistons also to determine the bore size prior to maching. Based near Birmingham
Old Nov 28, 2008 | 09:18 PM
rs tingle's Avatar
rs tingle
pm me with some details where you are i might pop up the weekend if i can get away from crimbo shopping lol
Old Nov 28, 2008 | 09:42 PM
bigchez's Avatar
bigchez
Mate I was running my car on a pretty tight budget and Martin's sorted me twice for VERY sensible cash. Go and speak to him.
Old Nov 28, 2008 | 09:45 PM
rs tingle's Avatar
rs tingle
i really am not far from martin he has sin me car a few times ill go see him if i gegt chance lol thanks mate you from the brummi area
ya might have seen mine about
Old Nov 28, 2008 | 10:55 PM
st3v3's Avatar
st3v3
rs tingle,
Why dont you ask Martin for some advise on what you need or want im sure for the price of a Bacon butty he at least talk to you and you could gain a wealth of information and save a penny or two aswell.
Old Nov 28, 2008 | 11:01 PM
rs tingle's Avatar
rs tingle
hes a nice person i took me white 3dr to him with a rattle i thought it was a tappet but it was summat jus vibrating .i could stay there all day an talk to him his info on cosworths is amzing im gona go see him 2moz
A.t.p
Sep 29, 2015 05:04 PM
20/20 vision
Sep 28, 2015 03:03 PM
SMILER258
Sep 28, 2015 09:04 AM
timsrs
22
Sep 24, 2015 08:14 PM
