CVH Cambelts
are cvh cambelts the same im changin my head tommorow on my ts turbo and i bought a 1.4 cvh cambelt a while ago for an old car will this fit my rs?? i should think there all the same?? cheeRS
i think some of the later cvh ones had PAS but if non then i believe they're the same
i think there all the same as long as it aint got PAS like paul said
just count the teeth on it ,a pain to count them all but worth it rather than just guessing
possibly, ask your local motor factors ;)
Well I used one on my Rs turbo after the rebuilt engine a month or two ago and it worked fine. It was intended for a Mk6 1.4cvh wheeze bag!
Well it worked fine until I realised I had the bottom pully washer on back to front and it started to shread the belt, so I had to go and buy another! |
there is 3 differant cvh belts
1.3 1.4/1.6 1.8 so the 1.4 will do for the rst no prob |
cheers guys i was gna count the teeth before fitting just thought id ask lol
What belts do people fit.
- Bog std Gates belt and tensioner kit? Got a 1.9 cvh, based on the 1.6 head and block. Belts quite new looking, but tensioners not, and it jumped a tooth a few weeks ago. Daniel |
© 2024 MH Sub I, LLC dba Internet Brands
