2wd diff removal how?
Old Nov 9, 2004 | 08:02 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
Default 2wd diff removal how?
havent even looked at it yet i belive its a simple job but can any one tell me what i need to do as i aint got a clue
Old Nov 9, 2004 | 08:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
juts rag the living tits off its till the fooker smashes to peices
Old Nov 9, 2004 | 08:27 PM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
exhaust off, half shafts off, prop off, diff mount off then diff locating bolts out jobs a good un
Old Nov 9, 2004 | 08:34 PM
deleted's Avatar
deleted
u make it sound simple why do i get the feeling its not
Old Nov 9, 2004 | 08:37 PM
dannyblackpool
Boost Builder
is easy enough actually
Old Nov 9, 2004 | 08:51 PM
SPADGE's Avatar
SPADGE
Watch it doesn't land on your head
Old Nov 9, 2004 | 08:58 PM
dannyblackpool
Boost Builder
or your chest
Old Nov 9, 2004 | 09:03 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
with spanners
Old Nov 9, 2004 | 09:05 PM
Rs Gus's Avatar
Rs Gus
one pice of advice tap the torx bit into the bolts in the drive flange or u will round them off
Old Nov 9, 2004 | 09:16 PM
Cossiep's Avatar
Cossiep
Top advice there
Old Nov 9, 2004 | 09:20 PM
Rhys's Avatar
Rhys
AS said above!!! And before you put it back just nock the cradle a bit just to open it out a bit! (though not to much) as it can be a coont to get back in and lined up!! The hardest part of it imo
Old Nov 9, 2004 | 09:21 PM
dannyblackpool
Boost Builder
AGHHHHHHHHHHHHH lactic acid build up
Old Nov 9, 2004 | 09:22 PM
deleted's Avatar
deleted
cheers guys this is a big job for me not really looking forward to it
Old Nov 9, 2004 | 09:27 PM
Rs Gus's Avatar
Rs Gus
takes me about 35mins
Old Nov 9, 2004 | 09:31 PM
Cossiep's Avatar
Cossiep
Sounds like a practiced man...... just like myself... got so many busted diffs could start a museum
Old Nov 9, 2004 | 09:33 PM
deleted's Avatar
deleted
gus your more than welcome to the job my friend
Rs Gus's Avatar
Rs Gus
me aswell half are going in a skip this weekend
Old Nov 9, 2004 | 09:34 PM
Rs Gus's Avatar
Rs Gus
your too far away mate ort i would have
Old Nov 9, 2004 | 09:35 PM
Cossiep's Avatar
Cossiep
Old Nov 9, 2004 | 09:37 PM
deleted's Avatar
deleted
thanks m8 appreciate the offfer
Old Nov 9, 2004 | 10:31 PM
Ginge !'s Avatar
Ginge !
well i might be able to free some time
Old Nov 9, 2004 | 11:01 PM
FletchCossie's Avatar
FletchCossie
Jack rear of the car up, undo the driveshafs (T50 hex shaped), easiest way Ive found is to undo the handbrake and take car out of gear spinning the wheels to access all the bolts, but putting handbrake back on if you have no one to hold the wheel in place while undoing them!
Once all 12 (IIRC) driveshaft bolts are undone and they are moved out the way undo the prop shaft in same way to access the 4 bolts (15mm bolts). Then undo the two top 19mm (IIRC) bolts first as these can thread when trying to get the diff back in if not lined up correctly, so take no chances!
Then support diff with a jack and undo the 4 13mm bolts holding the back plate to the chassis and remove the black bump stop thing (Slides into place on the chassis (IIRC). Then undo the centre nut and 2 front boltsand remove the 2 front ones! Then remove the long bolt (Exhaust may get in the way, depending which way the bolt is placed) and the diff should be free unless Ive missed something
It may need a bit of persuassion (Sp??) to remove it and get the rear mount over the rear ARB, but it should lower down
Hope that helps mate... Me bro fooked 24 diffs in a year and we were removing them every week to be rebuilt
Old Nov 9, 2004 | 11:06 PM
Ginge !'s Avatar
Ginge !
, foom me steve you deffo have done that a few times
ya got all the sozes ect, ya should write a hayne manual
hows ya cossie going btw
Old Nov 9, 2004 | 11:13 PM
FletchCossie
@ BBal... I had another mate of mine turn up @ 3am one night to change his diff over as he was going to a RR day @ 7am. We started @ 4 and finished around 6:30. I done most the diff and me bro changed intercooler and a load of other bits for him!! When I give advice I like to give as much info as possible Now CossieNuts can get all the spanners, sockets, etc ready before starting
Dunno bout me Esc Cos, been too busy to do anything tbh. Did the oil change yesterday and should really phone up to see how the gearbox is doing Just got so much other stuff to do atm
Old Nov 9, 2004 | 11:14 PM
Ginge !'s Avatar
Ginge !
heard ya got a saph now too
Old Nov 9, 2004 | 11:15 PM
FletchCossie
Thats me bro's toy Going in for painting at end of month... Wil be ordering engine soon hopefully
Old Nov 9, 2004 | 11:18 PM
Ginge !'s Avatar
Ginge !
the aint gonna be safe anymore then
the fletch brothers are back
Old Nov 9, 2004 | 11:23 PM
FletchCossie
Were already talking bout who's gonna win at Santa Pod in the Summer I should win off the line, ut he should win overall due to more BHP on the road His going Quaife diff so we dont have to keep replacing them
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
3doorcozmess
Sep 15, 2015 06:06 PM
hopper350
Sep 4, 2015 12:53 AM
