Stack Dash Owners
Old Sep 8, 2008 | 06:56 PM
Jasesapphy's Avatar
Jasesapphy
Default Stack Dash Owners
When i ran my ST8130 stack dash i used the pick up from the bell for the speed sensor, as im not running bells and rotors on the new sapph, what can i used for speed pick up
Old Sep 8, 2008 | 08:06 PM
Jasesapphy's Avatar
Jasesapphy
anyone
Old Sep 8, 2008 | 08:07 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
2wd or 4x4?
Old Sep 8, 2008 | 08:09 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill be using the back of the 4 wheel studs int he hub, when i make a bracket lol
mine is 2wd btw
Old Sep 8, 2008 | 08:11 PM
Jasesapphy's Avatar
Jasesapphy
2wd mart
Old Sep 8, 2008 | 08:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
front hub then mate, undriven wheel too, so no errors when reading wheelspin etc
Old Sep 8, 2008 | 08:15 PM
Martin-Hadland
2wd mart
If it was 4x4 I could have done you a transducer that fitted directly in place of the speedo cable, can't do this for 2wd.
You could use the driveshaft bolts by the rear diff or as Fudge says front hub ...
Old Sep 8, 2008 | 08:16 PM
Jasesapphy's Avatar
Jasesapphy
i will have to take a look, couldnt remember what the rear of the hub looks like and what bracket i can make and from where to mount it without looking
cheers
Old Sep 8, 2008 | 08:18 PM
Jasesapphy's Avatar
Jasesapphy
You could use the driveshaft bolts by the rear diff..
did think about the back somewhere readin off the drive shaft
Didnt want the expense of bell and rotor set up as its just a very cheap saff cos road car,like the stack dash though as it is 10 gauges in one, if you know what i mean
Old Sep 8, 2008 | 08:36 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the only problem with taking the reading off a driven wheel is wheelspin, but then, i guess its not that much of a problem.
probably much easier to mount it off the diff too. ill have a look when i next get the car out lol
Old Sep 8, 2008 | 08:46 PM
hicost's Avatar
hicost
Cosworth 7
Default Stack
You need one of these:
http://www.sailesmarketing.com/ProductDetails.asp?id=11
amd one of these:
http://www.westfield-sportscars.co.u...hFor=&PT_ID=78
Works perfect on a 2WD off a T5
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fordmad!
Sep 29, 2015 07:03 PM
rsguy
44
Sep 29, 2015 03:29 PM
Mc5506
Sep 29, 2015 09:06 AM
