480cc siemens injectors
Old Aug 25, 2008 | 05:51 PM
jonesymk2's Avatar
jonesymk2
Default 480cc siemens injectors
what power would these be good for on a cossie engine
Old Aug 25, 2008 | 06:54 PM
jonesymk2's Avatar
jonesymk2
anybody please
Old Aug 25, 2008 | 06:56 PM
mechanic28's Avatar
mechanic28
alot more then what u want!cant remember anyone fitted them to a cossie?could be wrong tho!
Old Aug 25, 2008 | 06:57 PM
mechanic28's Avatar
mechanic28
your after 350 bhp aint ya?
Old Aug 25, 2008 | 07:00 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Maybe 400 at a push.. but you can always tweak the fuel pressure up a bit if you really need to. Yeehaw.
jonesymk2's Avatar
jonesymk2
yeh about that mate maybe a little more but not much more really as going 4x4
Old Aug 25, 2008 | 07:02 PM
mechanic28's Avatar
mechanic28
dark greens T34.48 and you will close enough
Old Aug 25, 2008 | 07:04 PM
jonesymk2's Avatar
jonesymk2
would light blues be to much then aswell mate
Old Aug 25, 2008 | 07:06 PM
mechanic28's Avatar
mechanic28
i am on light blues at the mo they are rated about the same as the seimen ones!u need a fitting kit for the light blues the same as for the grey injectors
Old Aug 25, 2008 | 07:08 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
...deffo wouldn't go with greens..........light blues or the seimens......but ask whoever is going to set up/map it for there advise
Old Aug 25, 2008 | 07:11 PM
mechanic28's Avatar
mechanic28
as above it does not matter if u go with light blues or the seimens ones as long as its mapped correctly etc!you can use greens for the power but they will probably be maxed out or very close to it!
jonesymk2's Avatar
jonesymk2
what does the fitting kit include
Old Aug 25, 2008 | 07:12 PM
jonesymk2's Avatar
jonesymk2
so would the siemens injectors be ok just a bit bigger than i need
Old Aug 25, 2008 | 07:13 PM
mechanic28's Avatar
mechanic28
its just goes on the end of the injector so the injector can fit into the manifoldu need to cut abit off tho otherwise it effects the spray pattern!mine came with the kit already fitted and cut!but it easy to do form what i gather
Old Aug 25, 2008 | 07:14 PM
jonesymk2's Avatar
jonesymk2
not sure who im going to get to set it up yet as its a long way off before it will be ready
Old Aug 25, 2008 | 07:15 PM
mechanic28's Avatar
mechanic28
i presume these are the 55lb ones?should be good as long as u get the correct chip etc plus u dont need a fitting kit for these!
jonesymk2's Avatar
jonesymk2
ok cheers mate will see what comes up
Old Aug 25, 2008 | 07:16 PM
jonesymk2's Avatar
jonesymk2
ive spotted them on ebay mate and all it says is siemens 480cc injectors
Old Aug 25, 2008 | 07:17 PM
mechanic28's Avatar
mechanic28
oh u dont need the fitting kit for the greens either just incase u did not know
mechanic28's Avatar
mechanic28
ah ok fella just not heard of them called that before fella might be worth asking him if they are etc
Old Aug 25, 2008 | 07:18 PM
jonesymk2's Avatar
jonesymk2
ok cheers mate much appreciated for the help
Old Aug 25, 2008 | 07:19 PM
jonesymk2's Avatar
jonesymk2
yeh will send the bloke a message later on cheers
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
